Hey everyone ! Temp gauge/fan run on, problem solved
Here you can easily see the corrosion, that is the fan1 relay area that is all corroded.. the boost post sticking out of the underhood fuse panel lets moisture down into the circuit board ??? Dumbest thing I’ve seen I awhile, car has 84,000kms and this is ridiculous Dealer says there is none available, “on back order” $750cdn if you can even get one... I’m going to attempt having this one repaired and see what happens I’ll post results.
