new but need help please!
Old Dec 24, 2014 | 05:05 AM
ssst206's Avatar
So i recently replaced the flex pipe on my 06 ss. One of the black wires on the sensor broke off in the process. But i was driving my car afterwards for about an hour, hour and a half. Did 2 1/4mile runs and my car started to hesitate and lost lots of power (was almost oit of gas so i thought that was the issue so i put gas in it). Problem still persisted. Drove home and once i finally stopped on the off ramp my car jusy died at the light. Tried starting it. Itll crank but not start except when i give it some gas. Once it starts i either have to hold the pedal to keep it running which if rmps go below 1500 it stalls and dies. Or if it starts and runs on its own and i give it gas it stalls. Car does have blow by (idk what exactly it is). But i unplugged the battery for a night went out and hooked it back up and it started right up (after codes were cleared) but died when i gave it gas after i let it run for a few minutes... as it stands now, the only codes im aware of is a misfire on cylinder 1 and the manifold absolute pressure was wrong. Car drove perfect before replacing flex pipe. Any advise would be nice. I just bought this car and its been nothing but issues. Car would top at wot at 100mph on the way home too.
Old Dec 24, 2014 | 06:16 AM
Mr.Tozzi's Avatar
Fix the sensor, then come back.
Old Dec 24, 2014 | 10:02 AM
blueLNFftw's Avatar
What is with the rapid increase of retards posting here?
IF you car was fine AND you broke something on it THEN common sense says fix that part first.
Also, why do people feel it is necessary to beat on their obviously broken cars to further affirm that it is indeed broken?
Old Dec 24, 2014 | 10:43 AM
double clutch's Avatar
What is with the rapid increase of retards posting here? IF you car was fine AND you broke something on it THEN common sense says fix that part first. Also, why do people feel it is necessary to beat on their obviously broken cars to further affirm that it is indeed broken?
Because they are retards
Old Dec 24, 2014 | 10:48 AM
umrdyldo's Avatar
Be nice guys. It's Christmas Eve.
Although Christian tradition is to rape and pillage so I guess it's free game.
OP, you will need to buy a new 02 sensor and replace the one you screwed up. Not too hard to do.
Old Dec 25, 2014 | 02:23 PM
ssst206's Avatar
All it was was a question. Are you guys saying that the sensor is what caused it or is there something else
Old Dec 25, 2014 | 04:09 PM
ssyellow's Avatar
We don't know because you never specified what sensor you broke.
Fix sensor, check emissions fuse.
Old Dec 25, 2014 | 04:45 PM
Fix what you broke then come back
Old Dec 25, 2014 | 04:54 PM
Mr.Tozzi's Avatar
You replaced your flex pipe, you broke the sensor, you drove the car with a bad sensor.
Now the car is not acting right. common sense says to fix what's obviously broken so you can accurately troubleshoot the problem.
Old Dec 25, 2014 | 05:19 PM
Originally Posted by Mr.Tozzi
You replaced your flex pipe, you broke the sensor, you drove the car with a bad sensor. Now the car is not acting right. common sense says to fix what's obviously broken so you can accurately troubleshoot the problem.
Alot of people dont have common sense
Old Dec 26, 2014 | 03:20 AM
ssst206's Avatar
Its the one after the cat on the down pipe. I dont know the correct name
Old Dec 26, 2014 | 04:25 AM
cluelessk's Avatar
Holy ****. Some people.
-Breaks **** then proceeds to beat the **** out of his car till it won't idle anymore.
How do you know it has blow by if you don't know what it is?
Also a bad secondary 02 wouldn't cause issues.
Old Dec 26, 2014 | 04:28 AM
ssst206's Avatar
Ive been told by people it has blow by.
Old Dec 26, 2014 | 09:24 AM
blueLNFftw's Avatar
Oh yea, and what is blow by?
Old Dec 30, 2014 | 06:28 PM
Tsbbzm's Avatar
Jedi Master
Welcome
Old Dec 31, 2014 | 10:54 PM
ssst206's Avatar
Took all the plugs out and 3 of 4 were covered in oil.
Old Dec 31, 2014 | 10:55 PM
Sl0wbaltSS's Avatar
rip engine.
Old Dec 31, 2014 | 10:58 PM
ssst206's Avatar
rip engine.
So my engines shot? It cant be like spark plug grommets or somrthing?
Old Dec 31, 2014 | 11:13 PM
There isnt supposed to be oil in the combustion chamber and definitely not on the plugs. Do a compression test.
Old Jan 2, 2015 | 04:59 AM
ssst206's Avatar
Would if i could get the car running. I assume it wont turn over because 3 of the 4 cykinders arent firing. So ima chamge it all out amd see if it helps
Old Jan 2, 2015 | 07:31 AM
Mr.Tozzi's Avatar
have your car towed to a mechanic before you mess it up more.
Old Jan 2, 2015 | 07:33 AM
blueLNFftw's Avatar
I think this is the first time I have seen a flex pipe replacement lead directly to a blown motor...
Old Jan 2, 2015 | 01:30 PM
cluelessk's Avatar
Try getting one of these.
Old Jan 2, 2015 | 04:15 PM
ssst206's Avatar
Its not in the cumbustion chamber. Its on yhe top of tbe plug. Wherr the boot covers the plugs
Old Jan 2, 2015 | 04:18 PM
ssst206's Avatar
3 of 4 are like this
