SS problems 😢
Old Sep 12, 2015 | 09:30 PM
Dope_SS's Avatar
SS problems 😢
Hi guys new member here and just looking for a start to the right direction. Just recently bought an 05 Cobalt SS and now it's stuck in first. The shifter moves freely into gears but 1st feels different. I'm coming to think it could be the linkage or something with the gear box. Then again I'm no mechanic nor do I know alot about these cars being the first one I've owned. Anyone else know the problem?
Old Sep 12, 2015 | 09:48 PM
CannonBalt's Avatar
Can you shift gears while driving?
I can gaurentee its your shift cables.
Mine had this problem, but with 3rd gear.
Old Sep 12, 2015 | 09:49 PM
Dope_SS's Avatar
Does not shift into any other gear. Stays in first no matter what you do.
Old Sep 12, 2015 | 09:51 PM
CannonBalt's Avatar
Check underneath your cup holders and see if the shift cable clamps are connected to the cables.
If not its something within the transmission
Old Sep 12, 2015 | 09:53 PM
Dope_SS's Avatar
It'd have to be in thwriting trany because the cables are all connected. But would you think it'd slip out of gear into neutral
Old Sep 12, 2015 | 10:03 PM
CannonBalt's Avatar
When you say first feels different, in what way is it different?
Try putting putting car into nuetral by manually moving the gears directly on the transmission
Old Sep 12, 2015 | 10:09 PM
Dope_SS's Avatar
Different as in it Doesn't slid into it like all the other gears. It feels like it can't go all the way in. It's kinda hard to explain. You'd have to feel it yourself. An ok I'll go ahead an try that tomorrow
Old Sep 12, 2015 | 10:13 PM
CannonBalt's Avatar
Horizontal stick movement is one cable and vertical is another. You'll know if its the cables by manually moving the transmission.
Old Sep 12, 2015 | 10:18 PM
Dope_SS's Avatar
Ok thank you. I'll try it out tomorrow and comment back if it's not the problem.
Old Sep 12, 2015 | 10:23 PM
CannonBalt's Avatar
Ill keep an eye out
Old Sep 13, 2015 | 05:24 PM
Dope_SS's Avatar
Ill keep an eye out
Nothing worked. I tried everything else. Gonna keep looking into the clutch, could possibly not be engaging. I'll just buy a bew tranny. It needed one anyway.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
