Nitrous Oxide N20
can i use nitrous with cruise ??
Old Apr 13, 2011 | 03:34 PM
Cobalt.101's Avatar
quick simple question, can i use nitrous hif i have cruise control ??
Old Apr 13, 2011 | 03:44 PM
RoelSS's Avatar
Not sure what you mean if you have "cruise control". Any Nitrous kit engages & sprays upon full throttle, at which point if your cruise control is active, it will disengage. Does that help?
Old Apr 13, 2011 | 03:45 PM
exiged's Avatar
I mean come on lets think about this logically. . . . cruise controll is used to maintain a steady speed, nitrous is used to increase it.
If your asking if you can have both physically equipped, yes.
The fact your asking this means you shouldn't use it.
Old Apr 13, 2011 | 03:49 PM
Acey's Avatar
I like the other one better
Old Apr 13, 2011 | 05:48 PM
Cobalt.101's Avatar
no i mean, where do i install the activation switch hif my throttle switch is electronic ?? theres no cable running from the gaz peddal to the throttle body
Old Apr 13, 2011 | 06:03 PM
BlueTurbo's Avatar
Trying to think of an appropriate response here...
Old Apr 13, 2011 | 06:05 PM
All In 360's Avatar
1 shiny rotor 3 not, part 2?
Old Apr 13, 2011 | 06:06 PM
donkeyballs's Avatar
CLCHNGO's Avatar
hahaha cmon.. dont be so harsh haha
Old Apr 13, 2011 | 06:08 PM
All In 360's Avatar
I know, it was cheap. It has that feeling. But as if it would work or not, ZZP did it right?
Old Apr 13, 2011 | 06:09 PM
Cobalt.101's Avatar
finaly i found my own answer,
That means you have to fabricate a mounting bracket for the switch and
adjust the placement of the switch to make it work right. Our nitrous kit utilizes a wire that you simply clip on the throttle position sensor (TPS) output voltage wire. The TPS voltage signal is sent to a programmable electronic switch that engages and disengages the system at a predetermined voltage threshold. Above the threshold determined for wide open throttle, the system activates. Below the voltage threshold, it remains dormant.
Old Jun 28, 2011 | 04:14 PM
red06SC's Avatar
link to original?
Old Jun 28, 2011 | 04:18 PM
redcobalt07's Avatar
Ask a stupid question...
Old Jun 28, 2011 | 04:25 PM
DiabeticKripple's Avatar
https://www.cobaltss.net/forums/susp...tf-zzp-247391/
look at what he says to me, what a dick
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
jrocstar
Sep 26, 2015 11:42 PM
TylerJHowell
Sep 21, 2015 06:47 PM
