Nitrous Oxide N20
cooling, nitrous?
Old Jun 15, 2009 | 10:17 AM
Preston's Avatar
cooling, nitrous?
I know nitrous can be used to cooling.
I have a friend that has a kit laying around, and i was debating on running the kit for cooling purporses only.
what shot would you suggest to run? 20? 25? 30? or what?
and i know how to hook up nitrous, i use to have it on my car..im supercharged now and need alot of cooling mods
Old Jun 15, 2009 | 10:19 AM
umrdyldo's Avatar
Just go with a meth injection kit unless the nitrous is really cheap.
I would run like a 20 shot if you are doing it for cooling.
Old Jun 15, 2009 | 10:35 AM
Preston's Avatar
well i am just gonna be using the kit, and eventually buying it if it proves good enough.
but i will be using both nitrous and meth for cooling, when i build i am gonna need it haha
Old Jun 15, 2009 | 08:28 PM
Jn2's Avatar
Jn2
if its cooling only, run a small shot...also is this a wet or dry shot?
Old Jun 15, 2009 | 08:36 PM
camshaft343's Avatar
I would deffinatly go with Meth if you are going for straight cooling mods..
Old Jun 15, 2009 | 08:39 PM
scott allen's Avatar
has anyone gained any hp by spraying n20 in the intercooler?
Old Jun 15, 2009 | 08:40 PM
FASTL61's Avatar
or you can give me the nitrous preston muahahahahaha jk
Old Jun 15, 2009 | 11:36 PM
operatic's Avatar
I've seen some turbo Camaro and Mustang guys do this, but they're idea of a small is a 75 shot. Go with a 25 and monitor the results.
Old Jun 15, 2009 | 11:39 PM
ssyellow's Avatar
there are kits to spray it on the intercooler so I would assume yes
Old Aug 19, 2009 | 01:18 AM
revhrd4's Avatar
Thats what im running. Got the gm stage 3 with the dynotune dry kit 21 shot for awhile and its ok.
Old Aug 19, 2009 | 01:57 AM
fjordbosun's Avatar
It works very well spray N2O onto the heat exchanger. Just consider this though. If you talking about an SS/SC the H.E. is nestled between the A.C. condensor and the radiator
to to get a spray bar on the H.E. would require alot of modification, you must spray directly onto the fins. Best to add a front mount H.E. and spray onto that. Another cool thing to consider is if you have a after market intake with an open element you will suck some N2O into the intake for added effect.
I run a DEI CryO2 system and from time to time I'll dump N2O through it.
I love it.
Old Aug 19, 2009 | 02:03 AM
EXsoccer1921's Avatar
you're gonna burn through that **** so fast if you use it for cooling only it won't even be worth it.
Old Aug 19, 2009 | 04:26 AM
fjordbosun's Avatar
Well yeah.....................nitrous oxide, like speed is a drug got to pay if you want to play
Old Aug 19, 2009 | 02:49 PM
no ****. but theres a point where youre just paying way too much for very little return.
Old Aug 19, 2009 | 05:45 PM
damien's Avatar
Using nitrous only for its cooling ability is costly. Using it for both its cooling and power capabilities is a much smarter idea.
Old Aug 19, 2009 | 05:54 PM
damien's Avatar
dennis69
Oct 20, 2015 04:49 PM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
TylerJHowell
Sep 21, 2015 06:47 PM
