Nitrous Oxide N20
Need solenoid for Auto Bottle Warmer?
Old Aug 21, 2009 | 01:50 AM
ChriSS/SC's Avatar
I have an automatic warmer by NX that im trying to install. I got it used and there's a solenoid attached to the bottle up top. Do I have to use this or can I make the warmer work perfectly fine and hold at the right temp without the solenoid?
Old Aug 21, 2009 | 02:04 AM
RA122324's Avatar
What? Please post pics or link to the exact item.
Are you sure you aren't talking about a pressure
transducer that screws into a gage adapter?
Old Aug 21, 2009 | 02:13 AM
silver187666's Avatar
i see pain in your future, a lot of hot burning pain
Old Aug 21, 2009 | 02:54 PM
fjordbosun's Avatar
It Is most likley a pressure tansducer that will turn off/on the heating element in the
bottle wrap. Look closely there should be a small srew that is for adjusting the switch.
If you go to the NX web site you should be able to down load instructions for your
particular kit, if you haven't already. You are going to need a pressure gage to get it set up right.
If it is in fact a solenoid it may be part of a remote bottle opening or emergency shut off.
Buying stuff used, you may not allways know what your getting unless you know who
you are buying it from.
Old Aug 21, 2009 | 03:44 PM
ChriSS/SC's Avatar
^ True. I got a remote bottle opener.. and a lean/rich cutoff switch. My friend said that the solenoid in the back is for the warmer so that's why I was asking. He's probably wrong then. I got lots of **** and I've never dealt with this so the nitrous itself is easy all these accessories are a bitch! Tom mind if I give you a call on saturday? I'll be working on getting it all running...
Old Aug 21, 2009 | 04:00 PM
fjordbosun's Avatar
Feel free, more than happy to help to answer anything I can.
turbochargedss2012
Sep 20, 2023 12:17 PM
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
