Nitrous Oxide N20
Couple questions from a N2O noob
Old Aug 27, 2009 | 05:10 PM
benjirman's Avatar
First I've read the sticky on N2O and it did help A LOT. Second I have a couple more "technical" questions regarding running N2O.
So I have a 2007 2.2L L61 with almost 70K miles on it, is it still advisable to run N2O? I've taken great care of the car, full syn oil every 3-4K miles and quality gas always.
Using this engine with a 2.4L Intake Manifold swap and a K&N Typhoon SRI I've been looking at the Dynotune Universal N2O kit, the price is right and they look to make quality stuff. Using this will I be tapping my intake for the jet? Or should I get the adaptor plate that's optional for the IM swap which I've heard is the way to go for tapping for the N2O.
I only want to run about a 50shot, not much but just a little extra push. As i'm a noob to N2O I plan to use a window switch and a WOT switch, when I do this do i use a monitor that comes off of one of the coils to monitor RPM? or is there an easy way to tap the ECU for this?
I know I had a few questions and I'm sure I'll have more as I go so thanks in advance for your help!
Old Aug 31, 2009 | 07:03 PM
benjirman's Avatar
Bump, no one can answer even one of these? Not even a flame for search or some such nonsense?
Old Sep 1, 2009 | 08:44 PM
exiged's Avatar
when i installed the wot box i got the rpm off the coil / ignition so you could do the same.
Old Sep 1, 2009 | 10:02 PM
benjirman's Avatar
Awesome! That should make the install not so bad.
Also I called around to local places to see how much a bottle fill is and they don't fill bottles here (rural wyoming) but they'll sell me a 290 lb tank for 150 + 47 for a 6 month rental, is that a decent price for N2O?
And has anyone else had a setup like this in their garage to fill their own bottles (I'm pretty skilled with Oxy, Acetylene, N2, He, etc but never used N2O), do you just use a fill hose? or do you need a regulator?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Solaris99
28
Mar 15, 2017 01:22 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
