Nitrous Oxide N20
Get car started after tapping into fuel line.
Old Apr 6, 2008 | 02:29 PM
fjordbosun's Avatar
I tapped into the fuel line at the test port for my nitrous install. I started the engine then
pulled the fuel pump relay, When the egine stalled I turned off the ignition and removed
the shrader valve and conected the fuel feed line for the NOS that goes to the fuel solenoid. Now the engine won't start what di I need to do to re-start?
Old Apr 6, 2008 | 02:31 PM
Raven SS's Avatar
click it to the start position (dont start it)and let the fuel pump kick on and prime the system (u can hear it) when it kicks off like 20 secs later u can start
Old Apr 6, 2008 | 10:00 PM
fjordbosun's Avatar
Thanks for the input but it didn't work. Is there a chance that I may hve damaged the relay
some how? Should I have just pulled the fuse? Any other thoughts? Thanks Again
Old Apr 6, 2008 | 10:09 PM
Red2.4SS's Avatar
check the pump fuse make sure its not blown
Old Apr 6, 2008 | 10:13 PM
originaladrian's Avatar
can you hear your pump priming your system?
lil_kano's Avatar
its installed wrong. i had same problem.
Old Apr 6, 2008 | 10:18 PM
the relay?
Old Apr 6, 2008 | 10:30 PM
fjordbosun's Avatar
No, all I hear is clicking from the throttle body, no other sounds and I tried the relay both ways no change.
Old Apr 6, 2008 | 10:32 PM
fuel pump fuse
Old Apr 6, 2008 | 10:38 PM
fjordbosun's Avatar
Fuel pump fuse is good anything else?
Old Apr 6, 2008 | 10:41 PM
Sunburst_SS's Avatar
make sure you put the relay back int he proper terminals on the fuse block....I know a bunch of people have put it in the wrong ones, like one spot off
Old Apr 6, 2008 | 10:42 PM
wow u sure?... ur fuel pump is not turning on. you can hear it when you turn everything on but ur engine. what did u touch electronics wise, i dont think its the relay but theres a small chance you could have put it in wrong.
he got to it while is was typing. damnit.. lol
Last edited by originaladrian; Apr 6, 2008 at 10:42 PM. Reason: Automerged Doublepost
Old Apr 6, 2008 | 10:54 PM
Red2.4SS's Avatar
Make sure that the fuel pump is comming on. if you can't hear it when the key is turned to run then check the relay to make sure its turing on. Maybe trade it with another one that is the same?
BTW you should come to some of the meets! woot
Old Apr 6, 2008 | 10:56 PM
D4u2s0t's Avatar
i did that when i took it out. put it back to the right one and it started right up.
Old Apr 6, 2008 | 11:08 PM
fjordbosun's Avatar
Yep you got it , I had it plugged in one set of holes off! swapped to the other set of
holes and it fired right up, just have to fill the tank! THHANKS
Old Apr 6, 2008 | 11:09 PM
NP! have fun
Old Apr 6, 2008 | 11:17 PM
lil_kano's Avatar
told you....
vjoel2011
Oct 2, 2015 12:11 PM
dennis69
Sep 17, 2015 12:52 PM
DisJuan
Sep 7, 2015 04:24 PM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
