Nitrous Oxide N20
Gm Stage3 nitrous jumper install
Old Jun 19, 2010 | 04:53 PM
Sizzle06's Avatar
Does anybody have a diagram of where to hook up the jumper to as far as the pin or connectors?Thanks
Old Jun 19, 2010 | 05:06 PM
RoelSS's Avatar
I'm not sure if this is the same for all years but here is an excract from the instructions from the 05
J1-42 'Nitrous Fire Button (+12vdc in)
J3-16 'Nitrous solenoid Relay (-12vdc out)
Hope this helps
Old Jun 19, 2010 | 05:15 PM
Sizzle06's Avatar
Thanks for the info man,i'll see if someone else chimes in about the difference in years.
Old Jun 19, 2010 | 07:00 PM
Pyros777's Avatar
Roel nailed it.
Heres the S3 Instructions from GM: http://www.crateenginedepot.com/pdfs/s3ins.pdf
Heres a pic of the J1-Blue connector:
And heres the J3 connector:
Old Jun 20, 2010 | 12:50 PM
Sizzle06's Avatar
Thanks Steven
Old Jul 11, 2010 | 08:00 PM
Sizzle06's Avatar
Ok need some help,i'm running the zex safe shot kit and it doesn't come with a relay for the solenoid.If you look at the diagram posted in the link above by pyros,you can see that it shows a relay in the diagram.Do you think there is a way around the relay?
Help!!!!!!!!
Old Jul 11, 2010 | 08:11 PM
rockSTAR_SS's Avatar
I had this same question. Thought about selling the wet kit and buying a dry kit because I'll be using the gms3 tune also.
Old Jul 11, 2010 | 08:14 PM
Sizzle06's Avatar
Old Jul 11, 2010 | 11:05 PM
RoelSS's Avatar
Gotta have the relay. The -12vdc out from the PCM will go to the coil (-) of the relay. The relay controls the heavier load which is the nitrous solenoid. Get a relay at the auto parts store. Strange how your kit didn't come with it.
Old Jul 12, 2010 | 03:39 PM
RoelSS's Avatar
Old Jul 12, 2010 | 03:43 PM
coopercharge's Avatar
The zex safe shot kit is meant to run without the pcm did you go with the wet or dry kit?
Old Jul 12, 2010 | 10:12 PM
ebristol's Avatar
Technically you should install the RED wire in J1-42 'Nitrous Fire Button (+12vdc in)
and the BLACK wire in the J3-16 'Nitrous solenoid Relay (-12vdc out) to match up the wire colors with power supply and ground.
But you get the idea.
Its a bitch. You basically have to take the harness apart.
Old Jul 12, 2010 | 11:30 PM
Sizzle06's Avatar
Originally Posted by daddydikk09
Whats deee point mayne, amateurs dont use nawwzzz, ive seen the way u drive u gota heavy foot
Somebody ban this guy!!!!!!
Old Jul 13, 2010 | 12:12 PM
ebristol's Avatar
He is gone.
I reported a bunch of his posts in other threads.
Old Jul 16, 2010 | 08:34 PM
Daddydik's Avatar
Where is EBRISTOL. U pig why r u giving false information
Old Jul 16, 2010 | 10:43 PM
Sizzle06's Avatar
Ok i hooked everything up and now i got the engine power reduced,does anybody know if any of the pins next to the jumper wires have to do with the throttle position because i'm throwing the p2127.
Help!!!!!
Old Jul 16, 2010 | 10:44 PM
Pyros777's Avatar
C1 Pin 43 = Accelerator Pedal Position 5-Volt Reference (2)
https://www.cobaltss.net/resources/pcm/05cobalt20.htm
I assume you've checked the wires already, but this code sounds like a short in the circuit somewhere. Does it persist when you disconnect the nitrous jumper from Pin 42?
Old Jul 16, 2010 | 10:46 PM
Sizzle06's Avatar
I haven't had a chance to pull the jumper out yet,thought i would ask before i pull it,thanks.
Old Jul 16, 2010 | 10:52 PM
Pyros777's Avatar
Yep. I'm thinking 42 and 43 are tied together inside the PCM, essentially making them part of the same circuit (thats how GMS3 uses TPS for the nitrous window). If removing pin 42 and clearing the code fixes it, then there might be a short somewhere along the path from Pin 42 to the nitrous stuff.
Old Jul 29, 2010 | 07:07 PM
leviticus88's Avatar
Did anyone figure out if the install is the same for all years and Cobalt or Redline?
Old Jul 31, 2010 | 02:54 AM
Pyros777's Avatar
They all use the same Atlas P12 PCM, and the instructions for the install have all GMS3 part numbers (OSIDs) in the heading, indicating it is the same for all.
Old Aug 11, 2010 | 02:55 PM
ebristol's Avatar
This is what the wiring diagram should look like with a Dyno Tune 4cyle Wet Kit.
Old Aug 11, 2010 | 07:17 PM
What size inline fuse should be between the battery and the relay going to the solenoids?
My NX system didin't come with or say anything about an Inline fuse, is this really needed?
Old Aug 11, 2010 | 09:42 PM
ebristol's Avatar
The fuse in the DynoTune kit is a 25. You should ask the NX guy on the forum. I think they are trying to become a vendor.
Old Aug 12, 2010 | 10:27 AM
Nitrousexpress's Avatar
Its not really needed. But putting a fuse inline is never a bad option.
