Nitrous Oxide N20
This is going to sound like a stupid question
Old Jun 7, 2009 | 04:29 AM
sonicman4458's Avatar
Red face This is going to sound like a stupid question
This is going to sound like a stupid question what is defenses between wet nitrous and dry nitrous
Old Jun 7, 2009 | 04:30 AM
Neon04's Avatar
delete your other threeadd
Old Jun 7, 2009 | 04:32 AM
what are you talking about
what
Old Jun 7, 2009 | 04:42 AM
08inBama's Avatar
in layman's terms:
wet nitrous: mixed with fuel before the throttle body
dry nitrous: only nitrous injected
I know that used to, when people had a warranty and would try to hide nitrous, they'd run a dry shot because wet nitrous leaves a "residue" behind that could be detected
also, you get more whp out of a wet shot, if you are running a 150 wet shot, that will just about be your whp output, where as you won't net 150whp off a 150 dry shot
Old Jun 7, 2009 | 10:35 AM
damien's Avatar
..Dry shots are typically net more whp vs the same shot on a wet setup.
Old Jun 7, 2009 | 04:07 PM
08inBama's Avatar
^ dry shots are a bitch to tune and usually DON'T...
a kick ass tuner probably could, but considering most people don't trust a dry setup or worry about fine tuning one, you're going to just about always see better results from a wet setup
a wet shot is easier to run, safer, etc.... and tuned properly, whatever size jet you run is pretty much what you are going to see on the dyno
I didn't even consider a dry shot(no I don't spray the Cobalt, lol), and put down 470whp with bolt-ons and a 150 shot on a LS1 trans am(with an automatic and a stall, which will generally dyno lower than a 6-speed car)
Old Jun 8, 2009 | 06:47 PM
shawn672's Avatar
dry shots produce more hp then wet shots, its very small difference though (maybe 3-4 on a 75 shot)
Old Jul 1, 2009 | 04:36 PM
nicksredline's Avatar
a dry kit with a GOOD tune will net more hp
Old Jul 1, 2009 | 06:15 PM
shawn672's Avatar
less then 2% more..
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
jimbofug007
Oct 2, 2015 12:06 PM
