installing a Purge Kit witout NOS
ok, if you want to purge something other than nos, the only thing i can think of is by getting a cry02 setup, and that is used to cool your Intake temps. I would imagine if you wanted you could run that setup and purge that
NOOOO
we need to not answer questions like this so they wont be asked and people will hopefully stop having horrid ideas!!
this is just part of the reason why the IRL and most of the other sub-compact world thinks the cobalt is a joke!
Yes you can purge c02. There is a kit called Cry02.
It's used to frost over heat exchangers and what not. Here is a link.
Here is a link to the purge system.
http://www.cryo2.com/products.asp?m=sp&pid=49
Here is a link to the rest of the stuff.
http://www.cryo2.com/products.asp?m=sc&cid=1
LSX RWD S/C conversion
what the **** is the point...is a better question.
you're either a) going to get the **** beat out of you when someone wants to race or b) you'll get asked to see your non-existant nitrous setup.
might as well get a fake blow off valve for the exhaust tip while you're at it.
you guys are horrible, if he wants to purge expensive N2o let him.
If i was you I would get the cry02 kit and spray it somewhere in the front, so if you want u can use it to actually lower temps too.
other then that, ebay sells kits that are just tubes connected to small co2 tanks in the car. u can do it for show.
Sep 28, 2015 12:51 PM
