Nitrous Oxide N20
Lower Or Raise
Old Feb 25, 2007 | 07:40 PM
SymbioteLT's Avatar
Lower Or Raise
If im going with nitrous, should I lower or raise the compression
Old Feb 26, 2007 | 04:27 AM
IonNinja's Avatar
what motor do you have? if I ever decided to build my motor I'd probably raise compression to 10.5:1 or 11:1
Old Feb 26, 2007 | 06:21 AM
Tha Cavi Kid's Avatar
thats what i would do too.
are you throwing spray at a stock motor, or building it to boost and spray the hell outta?
Old Feb 26, 2007 | 11:07 AM
SymbioteLT's Avatar
I got a 2.2, im probably going to spray a 75 shot max at a stock motor.
then eventually get conecting rods, pistons, studs, port and polish my stock head and spray a 100-125.
Old Feb 26, 2007 | 11:09 AM
hatrickstu's Avatar
careful with that composite intake manifold. if you get a backfire its gone.
Old Feb 26, 2007 | 11:14 AM
SymbioteLT's Avatar
yeah, i probably need to replace that plastic intake too.
dc has a really nice 1 but its worth over $1200
Old Feb 26, 2007 | 11:42 AM
you will be fine a 75 shot wet w/o out doing anything extra to the motor. i would change the plugs tho, and have a lil bit smaller gap'n
Old Feb 26, 2007 | 11:43 AM
SymbioteLT's Avatar
copper, right?
Old Feb 26, 2007 | 12:48 PM
06_ion2's Avatar
with the 75shot dont you use srt4 plugs?
Old Feb 26, 2007 | 04:28 PM
IonNinja's Avatar
NGK BK7RE's or Autolite 3922's
I've only heard of Cavi guys attempting to use SRT-4 plugs
Old Feb 27, 2007 | 07:08 AM
this cavi guy thinks using those is dumb.........
bigdeertz
Nov 17, 2016 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
