My Zex Nitrous Install
Originally Posted by obxmush
For those of you looking at the machine gun kit, don't waste your money. You can pulse it with your finger just as fast, and it is no louder than a regular purge. Kind of misleading on Zex's part. Better off just getting and LED purge and hitting the button quick...... I'm a lil angry I spent the additional 100 bucks.
Originally Posted by sunfirejoe
did u run the line from your bottle through your car, or underneath wiht the fuel justw ondeirng cuz im about to my install tomorow, im gonna do a complete write up, but yah please get back to em asap
Along the fuel/brake lines under the car.
Originally Posted by Woodyr007
HEy zinner, so how is it. Does it pull alot stronger at the top of the gears? Just curious, I am sitting on the ZEX page trying to decide if I should order the wet upgrade of not!!! Thanx
I ran it today and of course it runs stronger.
There is a couple people running a dry shot with bigger injectors, I think your limited to about a 50 shot dry before you pressing your luck.
Originally Posted by HackAbuse
It wont damage the blower, the blower used in the balt doesnt use a teflon coating as originally thought, it uses epoxy instead, so its nitrous safe
If it does oh well, I will have learned my lesson the hard way.
Originally Posted by zinner
The lines wsith the kit at 24 inches and they aren't long enough.
I just got the 4 ft lines in today and they are the perfect length.
Do you have some pictures of a better way or even a description?
im sure you could run a dry thru it but a very small one...and i wouldnt press my luck. as with most apps on a more or less stock car, a wet shot will be able to run a higher shot (not by much but noticeable) and will no doubt mix better (correct me if im wrong...). but I always say make sure you have a fuel pressure safety switch, and a window switch at LEAST. Good luck woody, if you need any help...you know where i work
Delta coupe
Sep 30, 2015 08:11 AM
