Nitrous Oxide N20
nos kit
Old May 3, 2008 | 02:44 AM
yellowltcoupe22's Avatar
nos kit
is there a full kit that can be bought that will work on the cobalt without havin to piece one together? im wantin to run a 75 wet shot on my 2.2.
Old May 3, 2008 | 02:54 AM
RoelSS's Avatar
This might work:
http://www.harrisspeedworks.com/shop...cat=364&page=1
Wet System
I used their 50 dry shot kit with the GMPP Stage 3 kit. Give them a call, maybe they can help you out.
Good Luck!
Old May 3, 2008 | 08:22 AM
409Cobalt07's Avatar
i wouldnt use a dry shot unless you are tuned for one. look at the sticky at the top of the nitrous section. it has all the information you need to get your 2.2 sprayed. Good luck!
Old May 3, 2008 | 08:24 AM
anthonyS88's Avatar
get a sniper wet kit on ebay. im almost sure it comes with everything you need to hook it up and its cheap
Old May 3, 2008 | 05:02 PM
yea i was lookin at the sniper kit but wasnt for sure that it was everythin i needed to run it. i'll look at it again and see what all it has. i been lookin at a zex kit too and kinda think it has what i need. i'll post the link to it and someone can tell me what they think. i know i'll need to get a bottle warmer and was thinkin bout gettin a purge kit to go with it to. and i've looked at the sticky for it but it didnt list a a full kit. just things you need to run it. i was wantin a kit number or somethin to that exstent..
ok here is the link to the zex kit i was thinkin bout gettin. they have a kit for a 55-75 shot but its the same price so i figured i'd just get the one with the bigger shot jets so if i want to go bigger later on then i'll already have the jets to do so.
http://www.compperformancegroupstore...NITROUSSYSTEMS
another thing is that if someone can come up with a kit number aaron at ttr said he could probably get us a good deal on the kit with a group buy. i think its for a nx kit though but that wouldnt matter to me.
Last edited by yellowltcoupe22; May 3, 2008 at 05:02 PM. Reason: Automerged Doublepost
Old May 3, 2008 | 05:03 PM
originaladrian's Avatar
zex and dyno tune both offer complete wet kits that will work on your cobalt. boh of theses are currently used by many cobalts. i would say zex just because the install is clean as hell. Both the fuel and N20 solenoids are in a little box off to the side
Old May 3, 2008 | 05:05 PM
thanks man. i noticed that the zex kit looked to be one of the best put together kits. thats kinda the reason im leanin to this kit.
Old May 3, 2008 | 05:07 PM
the only ting u really need other than the kit if u dont have is a CAI and most people will recommend u upgrade to the one piece manifold. form a 2.4
does the kit i listed look like it'll be what i need?
Old May 3, 2008 | 05:08 PM
yeah i will most likely order the 2.4 intake mani when i order the nitrous kit.
Old May 3, 2008 | 05:16 PM
ya thts everything, u will prob want some other "goodies" but ths not required.
for example- bottle warmer, digital window switch (nt sure the zzex might come with one), purge kit.
Old May 3, 2008 | 05:44 PM
i have the bottle warmer and purge kit on my list of things to get with it. for the window switch i was thinkin bout goin with a button on the back side of the steerin wheel but not sure on that yet. but the window switch seems to be the best way to go thou since it wont spray to early or to late.
ok im gonna order the zex kit i have listed above. that seems to be a good one and the price of it from ttr is hard to pass up. so now i just need to order the window switch purge kit and bollte warmer then i'll be set. thanks for the help guys.
Last edited by yellowltcoupe22; May 3, 2008 at 05:44 PM. Reason: Automerged Doublepost
Old May 5, 2008 | 11:07 AM
Spanky's Monkey's Avatar
2.4 mani is not a must i've been running a dynotune kit no problems at all on the stock intake mani.
Old May 5, 2008 | 09:56 PM
yea but i was wantin to get the mani swap anyways thou.
dennis69
Oct 20, 2015 04:49 PM
thewafflesareburnt
Sep 30, 2015 02:29 AM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
