Nitrous Oxide N20
plain and simple... 50 shot plus stage 2?
Old Aug 23, 2007 | 05:14 AM
syP's Avatar
syP
plain and simple.. will it work, and be safe?
co-worker of mine has a stage 2 balt and zex plugs.. thats all he has..
I told him i would find out from the car club if it will work.
will it be okay on the zex plugs and the gm stage 2 tune for a few passes down the strip, nothing to worry about?
and i guess i should ask, what would be safer for that exact setup... dry or wet?
(no flaming, i just need an answer) thanks
Old Aug 23, 2007 | 05:18 AM
skymynx's Avatar
i wouldnt use zex plugs. but otherwise yes hell be ok. i had nitrous on the car for a while, and was spraying a 50 shot on 2.7 inch pully. no problems. took it off when i put the meth on though. figured it would be overkill
Old Aug 23, 2007 | 05:22 AM
syP's Avatar
syP
would there be a problem with the zex plugs and the nitrous?
Old Aug 24, 2007 | 12:47 AM
ItalianJoe1's Avatar
Shouldn't be a problem, but i'd check with ZEX to make sure they say they are ok. I use NGK plugs and run the same thing you are asking about, a wet 50 shot on Stg 2 with a 2.8, and it runs real strong for such a simple mod.
Old Aug 27, 2007 | 10:11 AM
heyitsmikey1987's Avatar
did u change the timing at all?and the gap of the plugs?
Old Aug 27, 2007 | 10:21 AM
lsjwannabe's Avatar
wet shot is generally safer becuase it uses less fuel, but he is on a stg2 pulley so a dry shot would be ok. Generally when you go with juice you retune the car for a little less timing, so he might want to find someone with hpt
Old Aug 27, 2007 | 10:27 AM
InfinityzeN's Avatar
If he is only going to be running it for a few passes at the track and has everything tuned he should be fine.
Old Aug 27, 2007 | 04:57 PM
quickspec's Avatar
Or he can just get the gm stage 3 pcm!
Old Aug 27, 2007 | 05:06 PM
OniMirage's Avatar
i would drop the zex especially after seeing what they look like after 5 months on a modified cobalt
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 04:49 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
