rpm widow switch
rpm widow switch
whats the most reliable switch to use on the cobal?. i've heard zex switchs are deadly. what about the others? i'd prefer something with gear lockout. if that's whats killing our cars then point me in the right direction of a safer option.
b.t.w. this is the kit i'm ordering Edelbrock
Any Digital is better than screwing with pills. Not to take away from SS.net but the LS1 guys have a Metric Ass Ton of info on Nitrous.
Quick list of part to make sure you have.
WOT switch (sure it comes with the kit)
Fuel cut off switch (cuts power to fuel 'noid if N2O preasure drops to low)
A/F monitor(probly most important)
Gauges
and a window switch set above 3000rpm.
I am sure there is other stuff that will help, but with out one of the above you are risking your motor.
Gauges
could someone provide links to these.... Im looking for a window switch but I want something to lock out first gear cause its pointless to spray in first
DynoTune Two Stage RPM Window Switch / TPS has a multi gear lock out
Features:
* 2 independent channels
* Integrated wide-open-throttle detection
* Each channel has a multi-gear lock-out setting
* User configurable for rising or falling TPS signal
* Supports low voltage tach signals as low as 3 volts
* Works with irregular tach signals such as V10 and 3cyl
* Push-button programming with integrated LED digital display
* Compact rugged, waterproof design
www.dynotunenitrous.com
just an FYI, that Dynotune window switch is like the exact same thing as the Zex with a diff. logo on it so if you're scared of a Zex switch I wouldn't touch that either.
I personally have had 0 problems with my Zex window switch for close to a year now...
for me its pretty hard to floor it in 1st with traction so im thinking i can handle the msd and just keep a mental reminder that it will spray at WOT. I dont plan on going to the track anways without at least drag radials anyways so I might be useful. but the way things are going with money and everything I probably will be waiting till next year to finish the rest of the mods and by that time I will start buying motor internals and working on that
Original Hayden Fanatic
dont worry.. thats why i havent gone to the track yet with my car..... im still working on getting axles, control arm bushings if all the bugs are worked out of them, and traction bars.... i got a spare set of control arms right now so its just a matter of money and time and im just about out of time for this season cause i gotta buy steel rims and snow tires
just set the activation point back further and you wont need to lockout first gear. I've been thinking about moving my activation point from 3200 to around 3600 or so...by that time you should already be moving and shouldn't have any major traction problems. Plus when you shift in the remaining gears you're already at 4K+ anyway.
I'm gonna try that and see how it works, last time i was at the track activating at 3200 it was constant wheelspin for 1 and a 1/2 gears
Sl0wbaltSS
Nov 21, 2018 11:11 PM
