Nitrous Oxide N20
This is what you need to run nitrous - LOOK HERE!
Old Sep 8, 2008 | 09:28 PM
  #51
CBodnar's Avatar
Originally Posted by StrongIslandBalter
iam not a genious but would plustar sparkplugs be fine casue iam told that just those sparkplugs can add up to 5 horsepower what is another perforemance spark plug that can do the same and run nitrous? thanx
spark plugs really can't net you horsepower. that is like me telling you use my oil i made myself that is fully synthetic and looks green and it will give you all your hp and gain more than other fully synthetic oils. /fail
if you are smart and advertise something right you can get a bunch of idiots to follow and claim it works and then hire people to promote it. the smart people sit back and laugh knowing you can't gain hp off oil.
on a stock s/c cobalt. gas will not give gain you hp. it is a stock tune and regular vs v-power there is no difference. oil's there is no difference. spark plugs there is no difference. if u were however to say how you gap them can make a difference i'll let you slide on that one.
however if you take 2 different spark plugs both 1step colder and gap them the same. or close your not going to gain whp from one or the other. every person has there own say in these things and that is how i feel about the question you asked. 5hp of spark plugs damn.... i am going to buy them plus whatever else that company sells cause damn it must give me power.
Old Sep 27, 2008 | 03:57 PM
  #52
burnrubr88's Avatar
can i run 2 step colder plugs with a nitrous/meth setup? im running one steps now, but im gettin crazy misfires.
Old Oct 1, 2008 | 05:58 PM
  #53
IonNinja's Avatar
if you're misfiring I don't think a step colder is gonna fix the issue. maybe try closing up the gap on those plugs?
colder plugs wouldn't hurt but unless you're having issues controlling detonation its likely not necessary
Old Oct 16, 2008 | 08:18 PM
  #54
BlackLS's Avatar
I was looking at the dyno tune window switch and it says you might need a tach adapter and i was wondering if anyone knew anything about this or if it is needed
Old Oct 28, 2008 | 01:08 AM
  #55
IonNinja's Avatar
tach adapter is not needed, if you can set the window switch to 2 cyl mode then you are fine
Old Dec 5, 2008 | 11:50 PM
  #56
RA122324's Avatar
Originally Posted by IonNinja
7) Nitrous Blowdown Tube - Optional
If for some reason your bottle pressure reaches a high enough pressure to rupture the safety disk on the bottle (ie: leaving the bottle heater on), this tube will route the nitrous outside of the vehicle. SOME race tracks require these if your bottle is in the passenger compartment, check with your local track first to verify.
You should really rethink the "Optional" tag you have on a blow down tube. I know you posted that "some" tracks require it, but that's not really not convincing. A blow tube is an absolute inside a car, including the trunk, whether or not you're on a track or parked at home. I'm sure you've seen threads (like idunn's thread) about bottles exploding from excess pressure. A blow down tube can save your car and your life. It's way cheaper to refill a bottle of nitrous than it is to repair the damage an exploded bottle can cause. They're like $30, if that. Excuse the rant, this was just meant to be a simple suggestion.
Popular Blowdown Tubes:
Dynotune Blowdown Tube (P/N - 909)
Nitrous Outlet Blowdown Tube (P/N - 860-010345)
Almost forgot about the second part. Make sure the blow down tube you order is made it fit your bottle. They are not all the same.
Old Dec 6, 2008 | 12:07 AM
  #57
Why The Fast Race's Avatar
Lot of misinformation on the whole blow down tube deal.
A blow down tube is required when the bottle will be stored in either a fast back car or in the passenger cabin. This is do to the fact if the pressure disk ruptures the nitrous will release into the cabin to much nitrous will kill a person. If the bottle is in a trunk that is sealed or seperate from the cabin no blow down tube is required.
The exploding bottles is due to people destroying the structural integrity of the metal by torching the bottle.
In this case no blowdown tube will save you.
As the pressure is below the break point of the pressure disk but still higher than the fatigued metal can take so the whole bottle explodes not the pressure disk. Which causes the pics you've seen.
Old Dec 6, 2008 | 03:34 AM
  #58
RA122324's Avatar
I don't know the history of that guy's bottle. What I do know, is that unless your bottle is mounted in the back of pickup trunk or some other open area you need to run a blowdown tube. The trunk or hatch area of a car is not sealed off from the cabin are. Sure there should be a seal round the trunk to keep water from coming in, but that doesn't stop the air in the trunk from spreading through the rest of the interior of your car. Try this, stick a disgusting bag of trash in one of your friends' trunk and tell how long before you start to smell it.
Cliffs: Get a blowdown tube.
Old Dec 9, 2008 | 11:18 PM
  #59
cobaltboyss06's Avatar
would i have to do any timing wit a 35 shot
Old Dec 15, 2008 | 04:40 AM
  #60
stage2cobaltss's Avatar
awesome write up
Old Dec 15, 2008 | 07:53 AM
  #61
RA122324's Avatar
I would suggest pulling 1 degree but if you can't, there's no point in worrying about it.
Old Dec 15, 2008 | 08:38 AM
  #62
YelloEye's Avatar
Awesome write up man, got me thinking about buying a system now hmm....
Old Jul 7, 2009 | 09:06 PM
  #63
Downy_7's Avatar
Ok so i'm considering buying a nitrous kit for my car tomorrow. I have a 2005 SS/SC and my only mods are Injen CAI, 2.5 catback with no cat. Now my question is, Can i run a 50 wet shot with my current setup if i just get 1 step colder plugs? Your advice is greatly appreciated
Old Jul 7, 2009 | 09:08 PM
  #64
shawn672's Avatar
1 step colder for a 50shot
whenever you go colder, your car will make *slightly* less power while not under n2o
Old Jul 7, 2009 | 09:11 PM
  #65
Downy_7's Avatar
Ok thanks, so I'm picking up the kit tomorrow morning and ill get the plugs and see how she goes i guess haha
Old Jul 7, 2009 | 09:48 PM
  #66
shawn672's Avatar
i believe the general rule is 1 step colder per 50 shot, so if 2.2's want to run a 75-90shot they should run 2 steps colder
my ss/sc didnt feel any slower without spray with 1 step colder, but im sure it would dyno a couple less hp /shrug
Old Jul 20, 2009 | 04:26 PM
  #67
GPZRider96's Avatar
i think i might run a 50 shot... hmm... we'll see
Old Jul 20, 2009 | 05:48 PM
  #68
shawn672's Avatar
lots of ss/sc's have run a 50shot just fine, according to GM the engine can handle 35shot just fine, but of course they're being cautious. same with 2.2, they claim a 75 shot, but ive seen a couple cars run a 90-100 shot and havent had issues
Old Jul 20, 2009 | 05:51 PM
  #69
OneCOLDBIZL272's Avatar
good write up
Old Aug 28, 2009 | 05:40 AM
  #70
Floppin Nuts's Avatar
This is an awesome write up. Does anyone have pictures of their install or finished set-up?
Back in the day I ran a Zex dry-kit on a built 2.2 Cavalier. Melted the pistons and bent every valve with a very large shot. Nitrous is crazy fun, but expensive.
Old Aug 28, 2009 | 06:12 AM
  #71
jsscooby's Avatar
sweet write up
Old Aug 28, 2009 | 06:13 AM
  #72
Pictures would be cool ... pun intended
Old Jan 1, 2010 | 09:49 AM
  #73
navyac89's Avatar
drivin a 2.4...putting a wet 75 shot on...just wanted to make sure all i needed was 1 step colder plugs...do i actually need to go get it tuned on a dyno???...also does anyone know of places in virginia beach area who fill nitrous?
Old Jan 1, 2010 | 10:10 AM
  #74
shawn672's Avatar
you just need 1step colder, 2 would be better for a 75shot but with a 2step you'll see a bit less performance when not on the n2o
as far as filling it, no idea.. but look around for small race/performance shops
Old Apr 4, 2010 | 02:31 AM
  #75
Redbolt19's Avatar
Do i dare run nitrous on a stock ss. and if i can what size shot do i use.
