window switch??
window switch??
is it possible to run a window switch with the wot switch that my n2o kit came with? if so how would i wire that up to work properly? i want to run it like that so it'll only engage at wot and about 3200rpm to ensure i dont bog the motor on a launch.
the widow switch would be wired up first and then the wot switch is wired into the window switch. in a nut shell that's what keeps the car safe. if you need a schematic i'll write one up based off my setup.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
