Nitrous Oxide N20
window switch??
Old May 26, 2008 | 12:23 AM
yellowltcoupe22's Avatar
window switch??
is it possible to run a window switch with the wot switch that my n2o kit came with? if so how would i wire that up to work properly? i want to run it like that so it'll only engage at wot and about 3200rpm to ensure i dont bog the motor on a launch.
Old May 26, 2008 | 12:06 PM
YzRider452's Avatar
It sure is. Look on the Nitrous Express website and click installation instructions and it will tell you how to install everything you could possibly need.
Old May 26, 2008 | 12:07 PM
originaladrian's Avatar
u have to wire the WOT switch inline after the window switch
Old May 26, 2008 | 08:30 PM
thanks guys. i was havin trouble figurin that one out cuz they both work off the same wire.
Old May 28, 2008 | 11:18 AM
Spanky's Monkey's Avatar
the widow switch would be wired up first and then the wot switch is wired into the window switch. in a nut shell that's what keeps the car safe. if you need a schematic i'll write one up based off my setup.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
dieGone
Sep 23, 2015 10:20 AM
TylerJHowell
Sep 21, 2015 06:47 PM
