Nitrous Oxide N20
the WOT help
Old Dec 2, 2006 | 04:51 PM
  #51
06blackg85ss's Avatar
you don't use a relay if you use their tps setup.... that white wire on the window switch cuts it on and off per gear
Old Dec 2, 2006 | 07:16 PM
  #52
IonNinja's Avatar
seriously? if thats the case then I might have to get that.
so then connecting those without a relay I'm assuming that one white one goes to the TPS on the NMU, the other white goes to the TPS on the car, green to tach signal and then the NMU & window switch will have their own power and ground sources?
:edit: i see that in their instructions the window switch can't handle the load that the NMU produces so how does that work?
Old Dec 3, 2006 | 12:29 PM
  #53
yup.. thats the way I read it... I should have most of the wiring done monday or tuesday I'l be doing it on my lunch break at work....
the white wire is for a 5 volt switch which is what our tps voltage should be all that does it cut the signal to the NMU has nothing to do with powering it...
Turbo Johnny
Feb 21, 2019 09:41 AM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
007Buff
Jun 11, 2017 03:04 PM
007Buff
Sep 22, 2015 09:48 AM
TylerJHowell
Sep 21, 2015 06:47 PM
