Nitrous Oxide N20
zex nitrous done
Old Feb 4, 2006 | 12:32 AM
Brian MP5T's Avatar
Kool.
Old Feb 4, 2006 | 12:11 PM
traviskearney's Avatar
Originally Posted by Blown Ecotec
nope i meant the non-supercharged 2.2L, as outlined on page 26 in the gm build book:
"With a stock cobalt, the maximum nitrous jet you should use
is 75 hp. Nitrous Express offers a stand-alone kit which has
been tested and proven to work well. The Nitrous Express
Kit contains a single nozzle with a nitrous jet and a fuel jet.
Use a pressure tap on the production fuel rail for the fuel jet’s
supply. (Fig. 5)"
theres a number for tech service, take the time do your research before you post again please.
oh and im not a 'he' i am a 'she'
You quoted a guy named REDBASEBOLT.....HE was refering to a supercharged 2.0. The world does not revolve around you ms. condesending to all. And if you look at the pic at the top of the page, you'll see a pic of my engine. I have used a 75hp jet on my own 2.2L ecotec, so I think I've done the research. Now let's see if you have. What fuel jet works best with the 75 hp N20 jet in the 2.2L ecotec? 55-65-75?
Old Feb 4, 2006 | 05:30 PM
IonNinja's Avatar
wow you really need to pick up that gm build book, the stock ecotec 2.2l is good for 75 shot
I think what he was saying is that if you were running that 75 shot on the LSJ motor you would be posting about a blown motor right now.
He didn't say that the 2.2L couldn't take a 75 shot...
However I do know of one Redline owner that is running a 75 shot, hasn't blown it up yet.
Old Feb 4, 2006 | 06:15 PM
Brian MP5T's Avatar
Kool
Old Feb 4, 2006 | 11:55 PM
Roadrunner's Avatar
Why wouldnt the lsj be able to handle a 75 shot? i thought the internals on the lsj were reliable for 400hp like how the 2.2L is good for 250hp
or do i have my numbers mixed?
Old Feb 5, 2006 | 12:01 AM
zerotosixty's Avatar
Running any nitrous on a car with f/i is a bad idea, just asking for an engine fire.
Old Feb 5, 2006 | 12:18 AM
Roadrunner's Avatar
i disagree, its the setup that causes most problems
Old Feb 5, 2006 | 12:40 AM
JapEatr's Avatar
South Central *********
you know she drag races ecotecs for a living right?
FYI
Old Feb 5, 2006 | 05:47 AM
IonNinja's Avatar
I think there is a belief that injecting through the supercharger will cause damage too the blades. And of course injecting a larger shot into an FI'd car is just a little more risky.
I don't believe it has actually been proven that the LSJ or the blower can't handle nitrous.
Old Feb 5, 2006 | 02:11 PM
Roadrunner's Avatar
thought someone here tried it and proved that it did nothing?
Old Feb 7, 2006 | 11:02 AM
  #36
Blown Ecotec's Avatar
holy **** you little *****. i am so god damn sorry to have offended you, read the damn posts.
he was spraying his 2.2L, thats a base model, thus the name "RED-BASE-BOLT"
you want to call me condesending, all i did was take a line out of the gm build guide.
go **** yourself, and then get some more pics of your fat ass girlfriend infront of your car to put in your profile, then **** yourself again.
by the way, with nitrous, you want to retard timing, and i personally have had the best luck running a 75 shot on an ecotec without any timing adjustments.
Old Feb 7, 2006 | 11:15 AM
  #37
R33P3R007's Avatar
360 L337 User
pwn3d
Old Feb 7, 2006 | 11:28 AM
  #38
BLKSS's Avatar
Originally Posted by R33P3R007
pwn3d
*Chows on popcorn* "Indeed".
Old Feb 7, 2006 | 11:32 AM
  #39
Brian MP5T's Avatar
This thread has taken a nose dive
Old Feb 7, 2006 | 12:12 PM
  #40
sorry
Old Feb 7, 2006 | 12:14 PM
  #41
R33P3R007's Avatar
360 L337 User
yeah it has... Mr. "cool"
Old Feb 7, 2006 | 12:39 PM
  #42
BlkSS4dr's Avatar
and how much you paid, where you ordered from, how the install was..... come on man....
noob....
j/k
O W N E D j/k
Old Feb 7, 2006 | 12:46 PM
  #43
BLKSS's Avatar
I have yet to see any proof that NOS's exist on Cobalts. Everyone talks about having them but thats about it.
Pics? Step by step? Video? link?
Ofcourse not.
Old Feb 7, 2006 | 07:45 PM
  #44
Roadrunner's Avatar
um isnt it a standard kit used for a 4 cyl non-carb car?
gravana has the NX kit available.
Old Feb 7, 2006 | 07:55 PM
  #45
[QUOTE=Blown Ecotec]holy **** you little *****. i am so god damn sorry to have offended you, read the damn posts.
by the way, with nitrous, you want to retard timing, and i personally have had the best luck running a 75 shot on an ecotec without any timing adjustments.[/QUOTE
Cussing like that.....that's classy. A size 5 is not fat. I have g-string pics to prove it. REDBASEBOLT said "HIS" car is not supercharged, refering to Maxss's car. Not his own. I am fluent in many languages so reading is deffinately not a problem. Although it looks like for you, it might be an area that needs a little work. And worst of all, you didn't even answer my question. I will no longer speak with you, as you are not worth the time. Good Day.
Old Feb 7, 2006 | 08:39 PM
  #46
BADZSS06's Avatar
as long as nitrous is used correctly and in the correct amount for you vehicles application it is totally safe. use the correct jetting and if all possible dyno the car for the correct a/f mixture. nitrous is supposed to be used above 3000 rpm. you also need to stay off the rev limiter if you hit it theres a good chance that the nitrous will puddle and then cause a back fire usually through the intake blowing either the filter up or the intake off.
if the a/f is off you could burn pistons valve sparkplugs and things like that on a lean mixture. on a rich mixture you will not get the optimum perf. out of the car.
extra info to know
wet kits are the safest cause they add the fuel in also, and it allows you to keep the factory a/f mixture when running on motor.
dry kits sprays just the nitrous. when using these your a/f mixture becomes even more critical. you should run the car a little richer so when the nitrous is sprayed you decrease the chance of detination. not saying it can't be done it is safer that way though.
ive used 75 to 250 jets in my camaro with no problems. the car is built for it though. used correctly it is totally safe.
Old Feb 7, 2006 | 10:30 PM
  #47
brandon11482's Avatar
I think hes holding back... c'mon Brian... speak on it man... speak on it... Spraying into the blower asking for trouble??
Old Feb 8, 2006 | 02:07 AM
  #48
BlAckOnBLaCK's Avatar
[QUOTE=traviskearney I have g-string pics to prove it.[/QUOTE]
......so how bout them pics?.......
Old Feb 8, 2006 | 05:36 PM
  #49
[QUOTE=BlAckOnBLaCK]
https://www.cobaltss.net/gallery/sho...php?i=3510&c=3
Old Feb 9, 2006 | 01:15 PM
  #50
HAHA NICE
so does your sister know you posted pictures of her ass on the internet?
