Nitrous Oxide N20
Zex Nitrous Pics
Old May 29, 2006 | 09:30 PM
cobaltltblue's Avatar
i programmed my zex kit Alone. it gives you pleanty of time to walk back and forth. i love the zex kit
Old May 29, 2006 | 09:55 PM
IonNinja's Avatar
did you have any issues or anything that kind of stumped you a little bit when installing it?
Old May 29, 2006 | 10:09 PM
no it was stright forward. i have mechanical experience and do all my own work. it's an easy kit
Old May 30, 2006 | 03:11 AM
Fatalis's Avatar
Ninja, im running the NGK 7e plugs i mentioned in my earlier post. Im going to order another set and give them a try, but im not sure yet. Elvis keeps saying to use his srt4 plugs, but i have no clue about those.
Also, if the NX express is harder than the Zex kit, the zex kit should be a breeze. I intalled the NX kit with ease and it worked the first time I sprayed on it, so zex should be loads easier. Im working on the ion nitrous install at this time too, ill probably be done by the time you order your kit.
The only thing i dont know is where to get the TPS signal. Im guessing near the ignition thing that i put my RPM tap?
Old May 30, 2006 | 11:11 AM
no no the tps (throttle position sensot) will be on the throttle body. there should be a plug on the throttle body. use a volt meter to check with the car on, on wire will have almost no voltage the when you open the throttle it will jump up to 5 volts or close to it. the motor does not have to be running. on the newer cobalts we have a drive by wire (no throttle cable) so you will need someone to move the peddle.
Old May 30, 2006 | 05:53 PM
IonNinja's Avatar
I know the plug that you are talking about cobaltblue, which color wire did you tap into? I'm pretty sure it'll be the same on 05+ Ions.
Old May 30, 2006 | 08:49 PM
it depends do you have a throttle cable or not? i'll go look..... it's the purple one closest to the front top. hope i coild help.
Old May 30, 2006 | 09:01 PM
IonNinja's Avatar
no all 05+ Ions are drive by wire just like the Cobalts thats why I ask.
But thanks for the info...I'll keep that in mind when the time comes. Hopefully not too far off...
Old May 30, 2006 | 11:38 PM
maybe you could meet up and i could help you out.... wait AZ LOL
Old May 31, 2006 | 01:51 AM
IonNinja's Avatar
road trip
Old Jun 3, 2006 | 11:26 PM
  #36
zinner's Avatar
Moderator Alumni
Originally Posted by obxmush
Oh yeah, just a techincal bit. The zex kit has a built in tps switch. Tap into the purple wire on the ETC harness. Just to make sure, turn the car to the on position, but do not start it. Hook up a volt-meter to the purple wire. It should jump to about one volt. Go inside and step on the throttle(all the way to the floor) the volt-meter should jump up to around 5 volts. That is your wide open throttle. With the zex kit, hook into that. Arm the system, on the side of the purple control box is a button, push it. The led light on the side will turn red, with the car in the on position(not running) push and hold the throttle pedal to the floor for 10 seconds. The led on the side of the box should now be green. Turn the system off then on, if you push the pedal to the floor and let off you should hear the solenoids opening and closing. Now it is programmed for your tps........
Thanx for the tip. I am in the middle of installing my zex system right now. Waiting on some longer 3AN hoses since I wanted to mount my NMU farther than two feet away.
Old Jun 4, 2006 | 06:19 PM
  #37
obxmush's Avatar
The Zex kit is great, other than the hose lengths. I can understand whay they make them short but at the same time it sucks. And of course I have the patience of a fly, so I had to install it the second I got it
Old Jun 4, 2006 | 06:21 PM
  #38
i wish i had a purge kit just for the show. go a video?
Old Jun 4, 2006 | 07:12 PM
  #39
Brandon97Z's Avatar
obx-you sprayed yet?
Old Jun 4, 2006 | 07:48 PM
  #40
obxmush's Avatar
I'm done my first friggin bottle already. It hit's great, not too much that it feels like my ***** gonna fall apart, but a great pull. I don't have any video of the purge, after I get the bottle refilled I will take some night time pics of it. Oh and word to the wise......Zex claims the machine gun purge is so loud, Save your money, if you want the looks get a regular led purge and push the button really fast. Thats all the control module does. It's not loud, and if i wanted to I could rapid fire it faster using my finger.......
Old Jun 4, 2006 | 08:02 PM
  #41
Brandon97Z's Avatar
get some track times please. and this is a 55 shot?
Old Jun 4, 2006 | 08:08 PM
  #42
obxmush's Avatar
Yeah it's a 55 shot. I wish I could get you track times in a timely manner, but the closest track to me is about 90 miles and it's only 1/8 mile. Pointless to me. Next time i visit philly and have some free time I will go to Atco New Jersey and run it....
Old Jun 4, 2006 | 08:10 PM
  #43
Doc's Avatar
Doc
Richmond has 2 1/4 mile tracks
Old Jun 4, 2006 | 08:19 PM
  #44
obxmush's Avatar
Richmond is about 2.5 to 3 hours for me
Old Jun 4, 2006 | 08:27 PM
  #45
hondaeater's Avatar
**** it.
Mush, Wanna go friday
The "other" Cobalt
Old Jun 4, 2006 | 08:30 PM
  #46
obxmush's Avatar
Lemme see if I can get my bottle refilled, then I'll hit up Doc to see if he can get the Hampton cobalts together, maybe we could all show up
Old Jun 14, 2006 | 03:39 PM
  #47
West Palm SRT4's Avatar
I guess it is me but nitrous isn't that appealing to me.
Old Jun 14, 2006 | 04:40 PM
  #48
Brandon97Z's Avatar
Here ya go
Old Jun 14, 2006 | 08:41 PM
  #49
obxmush's Avatar
So if you no like nitrous, why you lookin at it and droppin on it.
Old Jun 14, 2006 | 09:21 PM
  #50
zinner's Avatar
Moderator Alumni
See ya in my rear view
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 07:39 AM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
