2 red SS/SC's from CT claiming 300+whp on stock blower and no nitrous
I have been saying that for months now and nobody has done it yet. My car isn't modified enough to warrant such...plus I may be getting rid of it.
someone just needs to man up and do it and i guarentee that will be the next bandwagon mod... "DIY fuel return system"
The problem is if the fuel rail is too small and the injectors too large, the pressure will dip when the injectors pulse (even more so when the pulses overlap) because the rail doesn't flow enough volume for the fuel to pressurize it again.
I think the reason Cylinder 4 keeps blowing with the 60# injectors is because it is the last in the line and cylinder 3 pulses before and during the time 4 does resulting in lower fuel pressure for that injector and less fuel for the cylinder. Assuming the stock pump can meet the volume requirements, a larger fuel rail (and possibly fuel line) may fix the issue. Personally I would rather dump the stock pump, fuel rail and line for a Walbro 255lph pump with an Aeromotive fuel rail and boost referenced regulator running all -6AN line and add a return line.
I thought i had read where our fuel rails are rated at 700hp...pretty sure hahn has comfirmed this with their turbo 2.0 setup testing
I wholeheartedly agree about the return system though...it being on the end of the rail and having cylinder 3's pulse like it is does not help the situation at all...
well hopefully the rest of my parts come in today and I"ll be testing the limits of our stock fuel system this weekend with the turbo in..... I don't forsee any problems though @400whp...
have another motor built up on the side... still haven't blown the stock one yet somehow (knock on wood) just gotta send my other set of cams out next week to finish off the other motor
Actually, a good lot of us prefer not spending the money on something that you can't use all the time without having to worry about refilling the damn thing. I for one am not a huge fan of nitrous. My car should be a low 13 as she sits right now, and I am more then happy with that till I do a turbo swap. If I wanted a "fast" car, I would have bought a Camaro or TA WS6. Actually, I will be getting the second model year of the new Camaro.
Keep your nitrous...Nitrous for cars is like Viagra for people wit a broke dick. It's damn nice while ya got it, but what are you gonna do when you run out?? Tell the guy you can't race cause you have no more juice?? That would be like telling this hot chick that you can't have sex cause you forgot to get more pills....LMAO!!
