Any tuner in northeastern pa?
Old Mar 26, 2013 | 01:17 PM
Bluekid99's Avatar
Any tuners in the north eastern pa area looking to get my car tuned and looked at...anyone help out?
Old Mar 26, 2013 | 01:26 PM
CudaJoe's Avatar
BYT is in the Pocono's. Not sure if Nick is still tuning but he was one of the good ones out there.
Old Mar 26, 2013 | 01:28 PM
Terminator2's Avatar
When you say looked at are you having a mechanical issue with your car?
Old Mar 26, 2013 | 01:51 PM
Bluekid99's Avatar
Partially plus get suggestions
Old Mar 28, 2013 | 04:10 PM
He does not tune anymore.
Old Mar 28, 2013 | 04:13 PM
What issues are you having?
Old Mar 28, 2013 | 04:36 PM
Bluekid99's Avatar
I'm having a vibrating brake problem but no noise or anything only vibrations when depressing the brake pedal and the car seems to fall flat on its face at wot when over 5500rpm and I just and it's like the car does and comes back to life but if I'm not wot it doesn't do it...an I know the clutc isn't slipping bc I have no issues any other time
Old Mar 28, 2013 | 04:55 PM
Rotors are not even thickness all the way around and need to be machined or replaced along with pads ideally. Car giving any DTCs (MIL light on?)? My first thought is your plugs may need to be changed. Do not use any plugs other than the OEM AC Delcos as they are the proper gap and heat range for this car and will not cause misfires like the autolites and others out there.
Old Mar 28, 2013 | 05:19 PM
EcoWarrior's Avatar
There is a guy in Reading who does really good work for reasonable money. He tunes a lot of J's in the area(including mine) and works with LSJ swaps and his personal LNF solstice. His name is Ryan. If you're interested I can get in touch with him for you.
Old Mar 28, 2013 | 05:45 PM
Bluekid99's Avatar
I was assuming rotors and pads however plugs have been changed with the factory oem ones...yeah man if you can get in touch with him that would be great ...I want to tune but don't want to go over bored on price
Old Mar 29, 2013 | 10:54 AM
EcoWarrior's Avatar
Talked to him last night, he said he'd be down to tune. His prices are very reasonable and believe me when I tell you he has a fantastic reputation for tuning on j-body.org; he's the only person I trust with my car. Email address is rwl041@netscape.net. His name is Ryan.
Old Mar 29, 2013 | 01:50 PM
1AJeremyD's Avatar
I do tuning up here with my buddy in Lowell MA. We actually came down last year to norther NJ and had a bunch of people from NJ and PA come by and get some tunes either sorted out (BYT's doing) and come custom tunes done from the ground up. If you are interested let me know.
Old Mar 29, 2013 | 02:46 PM
EcoWarrior's Avatar
Do you guys have any experience with J-Body PCMs? I know a few guys from this area looking for custom tunes on SC & N/A.
Old Mar 29, 2013 | 03:13 PM
1AJeremyD's Avatar
Nothing with the J-bodys yet. Mainly LSJs and LNFs with a few LS4 in the impala/monte carlo. Shouldn't be a big going from the LSJ to the L61 tune wise. Tuning concepts still stay the same on non-direct injected engines. If you guys want to come by and hang out, we have a good group getting together this Saturday. You can view it through the link below:
https://www.facebook.com/events/448088081930277/
Old Mar 29, 2013 | 06:04 PM
EcoWarrior's Avatar
Awe man definitely let me know next time! I just liked you on facebook. Going to the RI meet tomorrow or I would definitely have come up there.
Problem with the J PCM is that we're stuck with Alpha-N tuning and even the SC setups have about half the tables of an LSJ cobalt. There's definitely some guess work involved, which is why experience is so important. Trifecta has blown up 2 turbo J's that I know of. If you're willing to burn the hpt credits you can pull the tune off of mine to see what I mean.
Old Mar 29, 2013 | 06:13 PM
GoodLuckBro's Avatar
Ryan tunes my car and is a great guy. I have a turbo swapped 2.4
Old Mar 30, 2013 | 09:40 AM
WB O2 sensor could be going out or you could have a bad purge solenoid which can cause misfires as the A/F swings all over the place.
Old Mar 30, 2013 | 12:15 PM
Bluekid99's Avatar
The purge solinoid was replaced already so I know it's not that and would the o2 throw a code?
Old Apr 1, 2013 | 01:29 PM
Sometimes it will throw a code but I have seen one go bad and take a while to throw a code.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
riceburner
Mid Central
Oct 5, 2015 09:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
09SSlow
Sep 28, 2015 12:37 AM
OPCrer
Sep 27, 2015 08:11 PM
