North Pacific WA and OR
Starter?
Old Jul 13, 2008 | 01:10 AM
06 Cobalt_SS's Avatar
Starter?
When I try to start the car, It seems as though I have enough power to run the car, but all i get when i turn the key is a click, anybody have any ideas of what i can do to get this car running soon. If it is the starter, where is it located, exactly?
Ok, so I tried jacking the car up and beating on the starter while someone cranked it over. Didnt work. I also tried giving it a roll to jump it off, pop the clutch, and all that jazz. Didnt work. It is still clicking once when i try to turn it over. I also tried jump starting the car in the back and the front. Didnt work. Will someone please help me out. i have to have this car running before monday. Its my only mode of transportation to work. If anyone has any ideas, please let me know.
Last edited by 06 Cobalt_SS; Jul 13, 2008 at 01:10 AM. Reason: Automerged Doublepost
Old Jul 13, 2008 | 01:11 AM
BLAZIN07SS's Avatar
I'm too JDM for you
have you tried giving it a jump or charging the battery?
Old Jul 13, 2008 | 01:17 AM
Afterwind's Avatar
Sounds like you got a dead battery my friend.
Old Jul 13, 2008 | 01:32 AM
I tried jump starting it, it didnt even try to turn over after sitting for a min with the jumper cables on, still just clicked. I dont know if its the starter, or maybe the clutch pedal sensor.
Old Jul 13, 2008 | 01:35 AM
Afterwind's Avatar
Maybe have the battery tested before you go any further.
Old Jul 13, 2008 | 02:15 AM
ok sounds good. I did notice almost everytime I shut the car down, all the gauge needles twitch, is this a common thing, or no?
Old Jul 13, 2008 | 02:17 AM
Afterwind's Avatar
Mine do. I hope it is haha. But they stop after a few `twitches`right
Old Jul 13, 2008 | 02:23 AM
yeah, i didnt know if it was common. if the battery was going bad, wouldnt the jump start at least try to turn the car over?
Old Jul 13, 2008 | 02:29 AM
Afterwind's Avatar
Was the connection good. And were you boosting directly from the battery or using an alt. location.
Old Jul 13, 2008 | 02:30 AM
pretty sure the connection was good, and i tried both from the battery, and the alt connection point
Old Jul 13, 2008 | 02:33 AM
twzted's Avatar
The needles twiching is your ECU shutting down...
try jumping the car again and make sure you have a good connection your ground could have been bad, you never know or your battery just failed
Old Jul 13, 2008 | 02:34 AM
JimzSS's Avatar
did you try push starting or bump starting?
twzted's Avatar
missed this post, but it never hurts to try again, jumper cables get cut/dmged?
Old Jul 13, 2008 | 02:36 AM
Afterwind's Avatar
But the ticking noise definately sounds like a battery thats cooked. Happens all the time at work.
Old Jul 13, 2008 | 02:38 AM
Tested the cables, they were good. I can take the battery and get it tested tomorrow. What chance do you think it is a starter or a clutch sensor vs. the battery
Old Jul 13, 2008 | 02:40 AM
twzted's Avatar
do your dome lights come on?
that is the first thing? do your accessories work? if not = battery...should tell you right there
Old Jul 13, 2008 | 02:41 AM
Afterwind's Avatar
90% sure. Are you still under warranty
Old Jul 13, 2008 | 02:42 AM
JimzSS's Avatar
push start it!
Old Jul 13, 2008 | 02:44 AM
All accessories still work. I mean everything, up to par.
I am still under warranty, and i already tried to push start it
Last edited by 06 Cobalt_SS; Jul 13, 2008 at 02:44 AM. Reason: Automerged Doublepost
Old Jul 13, 2008 | 02:45 AM
Afterwind's Avatar
Weird dude.
Old Jul 13, 2008 | 02:49 AM
twzted's Avatar
try disc the battery for a few min maybe there is a fault on the car and wont let you start...i dont know im out of idea since there isn't much else u can do
doesn't make much sense but wont hurt to try
its 3am here so im off to bed, hope you get this sorted...GL
Old Jul 13, 2008 | 02:53 AM
alright, I appreciate it. Im probly gonna take the starter, battery, and clutch sensor in and have them all checked if anyplace is open tomorrow
Tazmanian_Dvl's Avatar
It's a dead cell in the battery. If you have a dead cell in many circumstances you can't jump the car. Just because you have enough power to run the accessories doesn't mean the battery is good. My money is on the battery. However, there is a very slim chance that it may be the starter solenoid. Get a decent battery like a DieHard battery or an Interstate battery. Don't get an Optima battery they are completely junk IMO. I have one in my Camaro and I've been through 4 batteries in 3 years.
Old Jul 13, 2008 | 02:57 AM
Ok I really do appreciate it. But if it were a dead cell in the battery.why would it just quit out of nowhere, I came home after running errands, and went out to the car about 2 hours later and all this was happening
Old Jul 13, 2008 | 03:01 AM
Well in short cold damages a battery and heat kills it. You live in Washington so I'm guessin you have tough winters and pretty warm summers. So your climate is pretty tough on batteries. If it was hot today that could have put it over the top. A dead cell can pop up at any time. It's not a gradual loss of power when it goes. You wouldn't have noticed it when your car was running because once your car is running your alternator runs the car and you could actually take your battery completely out of the car and it would still run...
