Over The Top Performance Over The Top Performance is a supporting vendor.
Contacts: fast98 ; lsjwannabe
what injectors
Old May 22, 2009 | 11:43 PM
Sharkey's Avatar
what injectors
looking to buy a set of injectors. they are going into a 2.2 ecotec from an 05 cavalier (motor is in a 90 sunbird). currently we are running 42lb dsm blue tops and they dont fit properly, they are too short to fit correctly. im looking to upgrade to 60lb, what style of injectors do i need. i notice you list injectors for an lsj and for an le5, are the le5 injectors the correct length???
Old May 22, 2009 | 11:46 PM
o3nisoaso3's Avatar
LSJ injectors fit in a 2.2, im running stock LSJ injectors right now and a friend is using GM stage 2 for LSJ in his 2.2 but any for an LSJ should work out
Old May 23, 2009 | 12:12 AM
Sharkey's Avatar
the lsj injectors do work, however they are the same length as the dsm injectors. the dsm injectors we are currently running dont sit properly, if they are all the way into the rail they dont go past the taper of the cup in the head. the best thing i found is putting an o-ring in the rail before the injector, but its not the proper way.
the cobalt rail may also be different than the 03-05 cavalier return style rail. the 02 ecotec used standard length injectors, 03-05 are longer, and thats what im after, in 60lb of coarse.
Old May 24, 2009 | 02:15 PM
Sharkey's Avatar
anyone??? id like to buy these asap.
Old May 24, 2009 | 09:28 PM
lsjwannabe's Avatar
The 60's are a thin profile design and are pyshically longer than the 42's so if it is a length issue i do not believe you would want to use them. However i will check this to be sure.
Old May 24, 2009 | 11:45 PM
Sharkey's Avatar
longer is what im after, the 03-05 ecotec uses a longer than standard injector.
Old May 24, 2009 | 11:53 PM
lsjwannabe's Avatar
Will have a answer for you shortly
Old May 27, 2009 | 09:45 PM
Sharkey's Avatar
any answers yet???
Old May 27, 2009 | 10:01 PM
b_faulk75's Avatar
Hey i have an 05 cobalt 2.2l, i'm currently using gm stg 2 injectors, but i'm having the same problems with the injectors being 2 short, i am also looking to go to 60's. I know it has been done one the 2.2l balt but not sure on the cavi. waiting for an answer also. I'm turbocharged if your wondering.
Old May 28, 2009 | 12:19 AM
Sharkey's Avatar
if you have the same issue with them being too short. its been done in a cavy as well, but nobody seems to be talking much.
Old May 28, 2009 | 01:02 AM
lsjwannabe's Avatar
You would need to use ev1 ends on the current injecor harness to use 60's. There is not much information floating out there about them so it took me a while.
Old May 28, 2009 | 09:41 PM
Sharkey's Avatar
i did some digging last night and measured a stock 03-05 l61 injector, it measures 79.3mm overall length. upon further investigation, i found out that the 60lb injectors are a standard length of 74mm.
so basicly what im needing is a 60lb injector thats 79.3mm long to fit properly in the rail.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
