FS: Comp Cams Blower Grind Cams
Old Oct 15, 2007 | 10:10 PM
o4blackfire's Avatar
I used them on my 2.2l l61 motor for less then 1k miles before I had to trade in the car. I dont know if they will fit any other ecotec. Retail is 470, Im asking $350.
Old Oct 18, 2007 | 03:32 PM
bump.
Old Oct 18, 2007 | 07:08 PM
SS_SC_Cobalt's Avatar
specs?
Old Oct 22, 2007 | 08:10 PM
-Blower Applications power from 2800-7000rpm .423 intake and .436 exhaust valve lift, 252 intake and 262 exhaust duration advertized (210 intake and 218 exhaust @ .050" duration)
Old Oct 28, 2007 | 12:37 AM
Old Oct 28, 2007 | 09:14 PM
cavfiredesire's Avatar
these would be ok for turbo?
Old Oct 30, 2007 | 09:51 PM
they would work for a turbo but power on these cams is geared slightly lower in the rpm range then in the turbo grind. If your using a turbo rated to 350hp or less you wouldnt notice a difference.
Old Nov 4, 2007 | 06:29 PM
any serious offers?
Old Nov 12, 2007 | 09:56 PM
Old Nov 12, 2007 | 10:03 PM
spaz's Avatar
do they have the hex drive at the end of the exhaust cam?
Old Nov 13, 2007 | 10:37 PM
I believe the hex part is on the intake cam for the power steering pump.
Old Nov 13, 2007 | 11:05 PM
Delta2.2's Avatar
where in michigan are u located. if ur close its a possibility.
Old Nov 14, 2007 | 03:15 PM
Im in Holland
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
jimbofug007
Oct 2, 2015 12:06 PM
nathan112i
Sep 30, 2015 07:12 PM
goaliemo
Sep 28, 2015 01:37 PM
