LNF engine - Would not start - replaced it with an LDK - $500
Old Sep 15, 2018 | 11:43 AM
pearljamfan's Avatar
Selling a LNF engine. It is out of a HHR with an automatic transmission. Had 138k miles on it when pulled.
Vehicle quit on my wife while driving and was giving a code for the crank position sensor. It had compression so I pulled the front cover. The timing was still on but the fixed timinig chain guide was broke. When draining the oil there was coolant in the oil. I pulled the head and replaced the head gasket, water pump, timing chain tensioner, timing chain, balance chain, timing guides, balance guides, front cover gasket, spark plugs, and crank position sensor.. I also droped the oil pan and cleaned it out. After bolting in all back together, it still would start and still gave the code for crank postion sensor. I thought maybe the ECM was bad so I towed it to a Chevy dealer. They tried a new ECM and other things and could not get the engine to fire. I think there is probably play in the crank shaft or damage to the reculator ring that is causing the crank shaft position code. I don't have any need or desire to rebuild it so someone else could or pull it apart and use any parts.
I decided to replace the motor with a new LDK from ZZP instead of throwing more parts at it.
no turbo, intake, exhaust included what you see in the pictures is what you have
Engine is located in Baldwin, WI 54002 - 30 miles east of St. Paul, MN
So here is the engine.
Old Oct 12, 2018 | 12:22 PM
still for sale if anyone is interested or has any leads
Old Oct 12, 2018 | 08:26 PM
ohiocruiser's Avatar
Why would anyone want to spend $500 on high mileage broken engine??😧
Old Oct 13, 2018 | 02:05 PM
Maybe pull the parts they need make a coffee table? or rebuild it - or use it for a goblin project
Old Oct 25, 2018 | 05:25 PM
Lower price
$300
cheese9988
Oct 23, 2016 12:42 PM
YelCal7
Mar 18, 2015 05:43 PM
eco-tech
Jun 25, 2014 02:58 AM
TheNightWolf
Sep 9, 2013 09:44 PM
Koenreich
Nov 16, 2010 10:05 PM
