Timing Chain jump.
Old Sep 9, 2013 | 08:40 PM
TheNightWolf's Avatar
Timing Chain jump.
My timing chain on my LDK swapped balt jumped two teeth on the Cams.
So.
To reset it do I need to removed the chain entirely or is there an easier way to do this?
I can do whatever is needed, if I gotta remove the side cover I guess I will.
Old Sep 9, 2013 | 08:44 PM
BankerBalt's Avatar
you'll have to remove the cover and time it like it's brand new. you sure you didn't bend valves?
Old Sep 9, 2013 | 08:46 PM
Didn't lose compression.
So I hope not...Once its all back together I'm gonna do another compression check and see what happens.
I hope I didn't this engine has 1k miles on it.
Old Sep 9, 2013 | 09:43 PM
BankerBalt's Avatar
well you're gonna want to turn the crank by hand a few rotations to make sure valves don't hit... hope you did that the first time...
Old Sep 9, 2013 | 09:44 PM
The engine was timed by ZZP first. Not me.
And I hand turned it just a bit ago
All smooth.
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
