Wanted LSJ reluctor wheel
Old Apr 7, 2013 | 03:50 PM
Xmetalhead2003X's Avatar
LSJ reluctor wheel
Looking for an LSJ reluctor wheel for a SC build. I know someone has to have one around. Thanks!
Old Apr 7, 2013 | 04:49 PM
TStone's Avatar
Best bet is to PM Mongorat427
Old Apr 7, 2013 | 06:34 PM
Omiotek's Avatar
pretty sure all ecotec reluctor wheels are the same....... we might have one
Old Apr 7, 2013 | 07:01 PM
SlowBalt_06's Avatar
I thought one of them were clocked different?
Old Apr 7, 2013 | 07:19 PM
From what I've been reading, all are interchangeable between motors but the LSJ head requires the LSJ reluctor wheel to time. I'm looking to keep the L61 crank and block and run this LSJ head I've acquired. Also going to be running in a 2008 base model if that helps.
Old Apr 7, 2013 | 07:45 PM
ItalianJoe1's Avatar
I used to have one I pulled from a motor of mine, I think it's long gone though. If I come across it i'll let you know.
Old Apr 7, 2013 | 09:16 PM
Sounds good, thanks!
Omiotek, let me know if you have one available. Trying to source the harder to find parts right now and get this build going.
Old Apr 8, 2013 | 01:22 PM
cavi2sunfire's Avatar
Your reluctor wheel needs to be for whatever crank you have not head the timing gears are the same between L61 and LSJ. So if you have the 2.2 use a 2.2 reluctor the wheel tells PCM when to fire if you se the wrong gear your ignition will either be advanced or retarded
Old Apr 8, 2013 | 02:08 PM
Tjolley's Avatar
The lsj and le5 r different.
Old Apr 8, 2013 | 02:41 PM
So this would probably explain why Crate Engine Depot markets the timing kits as LSJ/L61 yes? Good news then.
Old Apr 8, 2013 | 08:56 PM
shanghai_todd's Avatar
I have an LSJ reluctor if you need it. Sent PM
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
