For Sale LsjIon Ported m62, 80# Injectors
Old 01-27-2015, 09:49 PM
Slobodan Milošević
07blackg5's Avatar
Bought a TVS and going with 1000's
Prices are OBRO.
ev6 80's. SOLD
LsjIon ported m62.
I got the m62 from a friend, and "rebuilt" it. It hasn't been run since the rebuild
-~65,000 miles on the rotor pack/snout
-Brand new case and needle bearings from zzp $150
-LsjIon ported the new case (leaving price off out of respect for him)
-zzp coupler $25
-zzp oil $10
The bearings in the snout seemed fine. The rotors are in great shape, and only have minor scuffs/scrapes on the flat part of the lobes (the usual spot that glides along the case)
Will come with an ottp hub, and a brand new 2.9 pulley. Snout is turned down for a smaller pulley.
Sealed with genuine GM sealant. Kept rotating it and letting it sit for a few days to check for leaks. I do have a new throttle body gasket I will include, but I will be keeping the sensor. I have the bolts for the bypass, but they aren't in the picture. Bypass is functional. The snout could use a finer cleaning if you plan on painting it, but I did the best I could with wire brushes. Taping off the case and using the small wire brush tool on a dremel would be perfect. I might clean up the snout if I have some free time.
EDIT: $375 Shipped FIRM!
I had the the openings taped off, but just pulled it off for the pictures. "no stick" my ass... haha
Looks rough, but it is much smoother than stock. Just asked him to "clean it up"
EDIT 1/29/15:
If my assembly is questioned. Anyone can open it up and reseal it for their own piece of mind for about 20 bucks. Like I said, this has not been run on a car, so I can't realistically say that it will be 100% leak free when the oil heats up. I can, however, guarantee that I am knowledgeable, assembled it properly, and it was done with care. This was to go on my personal build, so I assembled it as if it were my own.
07blackg5 is offline
Old 01-28-2015, 10:43 AM
Slobodan Milošević
07blackg5's Avatar
Early bump for the day
Old 01-28-2015, 03:27 PM
lsjion's Avatar
lsjion is offline
Old 01-28-2015, 03:38 PM
yellowsupercharged06's Avatar
hey josh, can you pm me some info on the blower. i have some questions about it.
yellowsupercharged06 is offline
Old 01-28-2015, 03:44 PM
Slobodan Milošević
07blackg5's Avatar
fyi, I only sent him the bare case. Only mentioning that in case it influences who your questions need to be directed to.
Old 01-28-2015, 04:30 PM
can you get a little video showing a slow and fast hand rotation of the blower so i can see all of the fins on the rotors please ?
i just have the ported blower questions, did he do it by hand ?
Old 01-28-2015, 04:32 PM
Slobodan Milošević
07blackg5's Avatar
As far as I know, it is hand ported. I will post a video after work today
Old 01-28-2015, 06:05 PM
lsjion's Avatar
I think it'd be good to answer all your questions publicly.
It was hand ported, yes.
lsjion is offline
Old 01-28-2015, 06:40 PM
Slobodan Milošević
07blackg5's Avatar
Per request:
not sure how to embed. tried everything.
Old 01-28-2015, 06:43 PM
Slobodan Milošević
07blackg5's Avatar
Thank you, Sir.
Old 01-28-2015, 07:09 PM
Have you seen gains on this kind of work? Dyno sheets or anything to show ?
Those blades look pretty beat up
Old 01-28-2015, 08:24 PM
lsjion's Avatar
Pretty beat up? I think they look better than 95% of the m62 rotor packs out there.
As for gains. Yes. It is typical to see a boost increase of 1-2 lbs, and a drop in iat's.
Typical power increase is generally 15hp.
A local customer of mine dyno'd 310 hp on a ported blower and ported head on his Lsj with a 2.6 and E85.
I don't do many blowers, mainly ported heads.
Alan McClure does a majority of them and has some more concrete numbers of direct swaps if you're interested.
This is the same design Alan uses.
lsjion is offline
Old 01-28-2015, 08:27 PM
Pretty beat up? I think they look better than 95% of the m62 rotor packs out there. As for gains. Yes. It is typical to see a boost increase of 1-2 lbs, and a drop in iat's. Typical power increase is generally 15hp. A local customer of mine dyno'd 310 hp on a ported blower and ported head on his Lsj with a 2.6 and E85. I don't do many blowers, mainly ported heads. Alan McClure does a majority of them and has some more concrete numbers of direct swaps if you're interested. This is the same design Alan uses.
I guess im **** about my car lol. My rotors are mint.
I have your head sitting here waiting to go on still lol. I think alan does it with a machine and not by hand i could be wrong though, which is why i asked you.
Thank you for the numbers though.
Old 01-29-2015, 07:56 AM
Slobodan Milošević
07blackg5's Avatar
how many miles are on your car? I'm not claiming these are perfection, but the condition of these rotors easily fall under the "normal wear" category for a driven car.
as for the blower as a whole, If my assembly is questioned. Anyone can open it up and reseal it for their own piece of mind for about 20 bucks. Like I said, this has not been run on a car, so I can't realistically say that it will be 100% leak free when the oil heats up. I can, however, guarantee that I am knowledgeable, assembled it properly, and it was done with care. This was to go on my personal build, so I assembled it as if it were my own.
Take that as you will, but I am not here to hustle anyone. Anyone who sells anything mechanical implies what I said above, but rarely say it. If someone reads that and is turned off of the item, that's fine.
Old 01-29-2015, 12:51 PM
lsjion's Avatar
Alan does use a machine to port the outlet. This, of course will will show imperfections, but there is no doubt that it will perform.
07black is a good guy, I wouldn't endorse his parts if I didn't have confidence in what he's selling.
Good luck to the both of you.
Ps- get that head put on already!
lsjion is offline
Old 01-29-2015, 02:43 PM
Slobodan Milošević
07blackg5's Avatar
Thank you, Sir.
The engine will be built in the next coming months. Hopefully. haha I've been saying that for years now
Old 01-29-2015, 11:07 PM
JZ_poWer's Avatar
Maybe interested in 80s. Free bump
JZ_poWer is offline
Old 01-30-2015, 08:11 AM
Slobodan Milošević
07blackg5's Avatar
Thanks, just let me know
Old 01-30-2015, 08:42 AM
Administrator
Administrator
Staged07SS's Avatar
Those rotors look fine...
That is normal wear.
GLWS.
Staged07SS is offline
Old 01-30-2015, 07:50 PM
Pitbull2o08's Avatar
I have a G5! Let's do it!
Pitbull2o08 is offline
Old 01-30-2015, 08:07 PM
Slobodan Milošević
07blackg5's Avatar
The g5 shuffle?
Old 01-31-2015, 06:06 AM
Would need some help installing.
Old 01-31-2015, 09:52 AM
Slobodan Milošević
07blackg5's Avatar
If you are referring the the blower, there is A LOT more that you will need. The blower wont just bolt on to your 2.4 without the rest of the lsj parts.
Old 01-31-2015, 12:07 PM
Slobodan Milošević
07blackg5's Avatar
Forgot to add that the bolts were torqued to 22ft/lbs. The specs I found said 17-22.
Old 01-31-2015, 12:51 PM
lsjion's Avatar
I have the other parts needed if someone wanted to buy this blower and needed the rest of the kit
lsjion is offline
Quick Reply: For Sale LsjIon Ported m62, 80# Injectors
