My Retrofit Build:
Old Jan 7, 2013 | 09:06 AM
  #51
padlock's Avatar
^winna winna chicken dinna
either that or if you have the shroud centric rings you just dab some 1 min epoxy on them and slide them over the projector last.. either way works.. method 2 I just described is better as i keep finger prints off stuff and its easier twisting the projector into place without the shroud on imo
Old Jan 10, 2013 | 10:35 PM
  #52
CannonBalt's Avatar
Sorry guys, Haven't checked this in a while:
It's the full Mini H1 Kit from TRS.
Ballasts, Bulbs, Projectors, Mini Gatling Shrouds and 4300K Bulbs.
Padlock, I ended up taking your route, The H4 washer wasn't working, and sitting flat with the amount of material I left over.
I ended up grinding it flat, and using both the H7 and H4 washers, as well as a set of 9007 Adapter rings from TRS. Makes it easy to centre.
Also, my projectors were rotating due to vibrations from my solid mounts, so I bought the 27MM socket to tighten them up nice and tight. All is well now and it's been a week.
I am debating making these and becoming a vendor, If the profits are worth it. May start with other vehicles too.
Old Jan 10, 2013 | 10:54 PM
  #53
padlock's Avatar
nice to see you got it all figured out. I always had similar situations with trying to use the small washer only so thats why I went to this "better method". glad to see it worked for you
as far as the vendor stuff goes, if you could make money being a vendor here doing this everyone would be doing it.... I just do a lot of stuff locally for the most part and it works out fairly well that way so maybe thats more something worth looking into for you honestly? Once the word gets out locally business can kind of explode on you if done right
Old Jan 11, 2013 | 03:12 AM
  #54
CannonBalt's Avatar
I know a guy in my building with a Hyundai Accent, With like 20,000,000,000K Bulbs in stock housings lol. I'm trying to convince him to let me build him a set, and tell his friends etc.
You're right, I should start off local and start there.
Raptorunbound
May 26, 2016 01:14 PM
SSnRXP
Dec 4, 2015 11:02 PM
themacguy
Aug 26, 2015 07:18 PM
Mercury
How to Guide
101
May 20, 2012 10:41 AM
IonNinja
Mar 15, 2007 02:20 PM
