06 LT Cobalt theft deturant issues
My theft deturent has been acting up in my car, when ever i open my door it will go off, just wondering is there a way i can dis connect it? If so where? If not what should I be looking for to fix the problem?
Does it have automatic locks (can be opened with a key fob)? If it's got automatic locks and you open it with a key, it will always go off. Get a fob or get batteries for the fob. That's about all you can do. No where to disable it or else the car won't start.
If you don't like the noise.....pull the fuse for the horn.
Only other thing I can think is check the battery in the car. When my dad's battery started going in his Blazer, the alarm went off CONSTANTLY, even while driving.
I have the same issue right now. I left the car for 2 days parked and the clicker wont work so i thougth it was the battery in the FOB. Replaced battery nothing!! I open thge door the alarm goes off and there is no power inside the car. the only that works is the gauge cluster nad the DIC. when you go to crank the car nothing happens. no power to inside door locks, windows will not roll down, inside lights will not turn on, radio will not turn when key is turned. what should i do?
Dustin24
10-08-2015 09:15 AM
