08 cobalt ss low speed vibration
Old Oct 9, 2019 | 12:39 PM
LnfMikey's Avatar
I have an 08 cobalt ss with an ldk and f40 swap. I vibrations/shakes in 2nd gear only at really low rpms, goes away after like 2500k 3kish rpm and you cant feel it in any other gear or higher speeds. Any idea what it could be? I also have axles from the driveshaft shop and zzp motor and trans mounts as well as bc coilovers. Thanks.
Old Oct 11, 2019 | 10:09 AM
Could be something wrong with the transmission if the vibration is only tied to one gear. Was the trans new or used? I would make sure all of your engine/trans mounts are tight and properly aligned.
Old Oct 17, 2021 | 07:54 PM
spooler's Avatar
I have the exact same issue. did you ever figure out what it was?
Old Oct 17, 2021 | 08:27 PM
Lnfmike's Avatar
for me it was the cv axles from dss that came with the kit from zzp. I ordered one axle from ottp and installed the old factory one from the f35 on the other side and problem went away.
ScreamingTurbo
Jun 2, 2012 01:58 AM
dwarrick
Mar 20, 2012 07:59 AM
IsItFast?
Jan 7, 2011 03:38 PM
bigwilly1384
Jan 6, 2009 01:57 PM
blackgloves
Apr 17, 2007 05:07 AM
