1st gear and reverse
Old Nov 13, 2009 | 03:21 AM
howardss17's Avatar
Angry 1st gear and reverse
my car wont move in 1st or reverse. wats wrong and how much to get it fixed
Old Nov 13, 2009 | 11:53 AM
bruiserinpink's Avatar
mine does this too sometimes, i would like to find out what other people have to say about this too!
Old Nov 13, 2009 | 01:23 PM
roboticfister's Avatar
What do you mean it won't move? The car will not pull forward or backward, or it won't shift?
Old Nov 16, 2009 | 12:38 PM
insylem's Avatar
What about second?
I can get my car going from a dead stop in second gear if I carefully feather the clutch and give it some gas.
Old Nov 16, 2009 | 12:42 PM
Acey's Avatar
...I wouldn't recommend making a habit of that.
Old Nov 16, 2009 | 01:21 PM
insylem's Avatar
Ya it was an accident. I'm relitivaly new to Manual transmitions, and I thought I was in first.
When I went to shift to 2nd and found i was already there it explaned why it was so hard to get going. Haha.
Also I know that my car will not start out in 3rd.
And your right it's not the best for it, But if it wont move in first,
then you could do it once for troubleshooting or to get the car going
home. My brother's S10 was low on clutch fluid and he
was unable to use 1st and second gear, He had to get his
S10 going from 3rd.
So ya, on that thought, Check your brake/clutch fluid.
Old Nov 24, 2009 | 05:03 PM
howardss17's Avatar
ill shift into 1st gear and let the clutch out and it wont move or at least it will do it very slowly and in 2nd gear it take me hitting the gas so it does idk
wont move forward or backwards and, it only does when i hit the gas some
Last edited by howardss17; Nov 24, 2009 at 05:03 PM. Reason: Automerged Doublepost
Old Nov 24, 2009 | 07:05 PM
mattcossel29's Avatar
Congratulations, you get to do a clutch job!
Save up for a new clutch and slave cylinder/throw out bearing!
Old Nov 24, 2009 | 07:08 PM
howardss17's Avatar
around how much is it gonna cost me
Old Nov 24, 2009 | 07:13 PM
I cant come up with exact numbers but with all oem parts my best guess will be... ~$1500-$2000
Thats including labor
Old Nov 24, 2009 | 07:16 PM
howardss17's Avatar
thats parts and labor? i have a friend that works for gm and will install it for 200
Old Nov 24, 2009 | 07:23 PM
http://www.crateenginedepot.com/stor...P1890C229.aspx
Everything you need
howardss17's Avatar
thank you i really aprecciate it
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
brett.higgins3
Sep 24, 2015 09:51 AM
