2.4 ecotec oil leak!!!
Old Feb 17, 2015 | 02:59 PM
Aaronl88's Avatar
Hey peeps. I have an oil leak on my cobalt that I've had for about two years Now and I can't figure out where it's coming from. I've replaced the oil pan gasket, and the timing chain cover. The oil seems to be leaking from the block behind/near the AC compressor, and runs down the subframe. Help!
Old Feb 17, 2015 | 04:19 PM
Spawne32's Avatar
Either the front cover seal or the crank seal on the cover. Crank seal is very easy to change, pop the belt off, zip the crank pulley off, yank the old seal out, oil the new seal, and tap it in gently with a matching socket. They come with a green cover that allows you to tap it into place to get it fully seated.
Old Feb 17, 2015 | 05:14 PM
Aaronl88's Avatar
I've already replaced the timing cover gasket. I bought the kit and I think it had that crank seal with it.
Old Feb 17, 2015 | 05:21 PM
Spawne32's Avatar
Did you torque the timing cover gasket properly with a torque wrench, and were you careful not to tear the crank seal when installing the crank pulley? Only thing I can tell you is try to locate what areas of the engine are wet and snap a few pics, check the rear of the engine by the timing chain tensioner, around that front cover seal, and around the crank pulley for wet spots. Go from there.
Old Feb 17, 2015 | 05:32 PM
Aaronl88's Avatar
Yep torqued them right, was real careful with the seals. In order to get a picture I would have to unbolt the AC compressor as it's directly behind it
Old Feb 17, 2015 | 05:35 PM
Spawne32's Avatar
You can take the plastic splash shield down as well to get a good look. I went through this as well, turned out to be the crank seal.
Old Feb 17, 2015 | 05:45 PM
Aaronl88's Avatar
It looks like it's leaking from a small pinhole from the block the last time I remember. I'll snap some pics here in a few days whenever I get some free time
Old Feb 17, 2015 | 10:18 PM
kzak104's Avatar
could be an oil gallery plug
Old Feb 18, 2015 | 11:55 AM
Aaronl88's Avatar
Never heard such a thing
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
Trav3480
Oct 1, 2015 08:17 PM
