2 interesting codes
Old May 18, 2009 | 02:06 PM
Sharkey's Avatar
2 interesting codes
i had the battery unhooked yesterday while welding a couple pinholes in my exhaust. i started the car for a minute or 2, shut it off, no check engine light. later i went for a drive, as soon as i started the car i found 2 codes
1)p0603- long term pcm memory reset- no big deal, i had the battery unhooked
2)p0001- this one has me stumped. nowhere in my gm service manuals, this site, or alldata can i find a p0001. according to the generic code list i found its for the fuel volume regulator control circuit open.
im going to assume the p0001 is a false code, it hasnt reset, but it kinda bugs me not being able to see a reason as to why it set.
Old May 18, 2009 | 02:30 PM
Coblasts's Avatar
You sure that it is a P code ,I found one that is a U0001( High Speed CAN Communication Bus)
Old May 18, 2009 | 02:59 PM
Sharkey's Avatar
deffinitly was a p0001
Old May 18, 2009 | 07:21 PM
Gene Culley's Avatar
Talking
P0010 is as low as they go. There is no code that you're mentioning.
Old May 18, 2009 | 07:36 PM
Sharkey's Avatar
thats the thing, however i can find p0001 for diesel pickups.
Old May 18, 2009 | 07:39 PM
I have access to the online service manuals from GM and that is not a code for a Cobalt.
xTooltipElement
Service Information 2007 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Diagnostic Trouble Code List
Basic Search Advanced Search
[change search type] Search Help
Search documents titles in the entire manual this section matching all any of these keywords: using this phrase: or find this Labor Op Code:
Symptom List
Please wait ...
Diagnostic Trouble Code (DTC) List - Vehicle
This master DTC list includes all applicable DTCs in alphanumeric order with descriptors.
The GMLAN modules on this vehicle also support DTC Symptom information. Refer to DTC Symptom Description for additional information on DTC Symptoms.
DTC
DTC Descriptor
Module That Sets the DTC
Diagnostic Procedure
B0012
Driver Frontal Deployment Loop Stage 1
SDM
DTC B0012 or B0013
B0013
Driver Frontal Deployment Loop Stage 2
SDM
DTC B0012 or B0013
B0015
Left Front Seat Belt Pretensioner Deployment
SDM
DTC B0015
B0016
Left Roof Rail Deployment Loop
SDM
DTC B0016
B0019
Passenger Frontal Deployment Loop Stage 1
SDM
DTC B0019 or B0020
B0020
Passenger Frontal Deployment Loop Stage 2
SDM
DTC B0019 or B0020
B0022
Right Front Seat Belt Pretensioner Deployment
SDM
DTC B0022
B0023
Right Roof Rail Deployment Loop
SDM
DTC B0023
B0052
Deployment Commanded
SDM
DTC B0052 or B0053
B0053
Deployment Commanded with Loop DTCs present
SDM
DTC B0052 or B0053
B0081
Passenger Presence System
SDM
DTC B0081
B0083
Front End Sensor
SDM
DTC B0083
B0085
Left Front Side Impact Sensor
SDM
DTC B0085 or B0086
B0086
Right Front Side Impact Sensor
SDM
DTC B0085 or B0086
B0158
Outside Air Temperature Sensor
BCM
DTC B0158
HVAC
DTC B0158
B0283
Electric Rear Defrost Circuit
BCM
DTC B0283
B0685
Security System Indicator Circuit Short to Battery
BCM, IPC
DTC B0685
B1000
Electronic Control Unit (ECU) Performance
BCM, DRR, IPC, Radio, SDM, VCIM
DTC B1000
B1001
Option Configuration Error
BCM, DRR, Radio, VCIM
DTC B1001
SDM
DTC B1001
B1004
Electronic Control Unit Identification Circuit
BCM, DRR, IPC
DTC B1004
B1009
EEPROM Checksum Mismatch
BCM, Radio
DTC B1009
B1019
System Configuration Error
SDM
DTC B1019
B1025
LF Audio Output Circuit
Radio
DTC B1025, B1035, B1045, or B1055
B1035
RF Audio Output Circuit
Radio
B1045
LR Audio Output Circuit
Radio
B1055
RR Audio Output Circuit
Radio
B1259
Antenna Ground Circuit
DRR
DTC B1259
B1325
Device Power 1 Circuit
BCM, IPC, Radio, SDM
DTC B1325
B1370
Device Ignition 1 Circuit
BCM
DTC B1370
SDM
DTC B1370
B1380
Device Ignition ACCESSORY Circuit
BCM
DTC B1380
B1424
Device 1 Voltage Low
TDM
DTC B1424
B1441
Device Ignition OFF, RUN, and CRANK Circuit
BCM
DTC B1441
B1480
Battery Rundown Protection Circuit
BCM
DTC B1480
B1516
Battery Current Sensor Performance
BCM
DTC B1516
B1517
Battery Voltage
BCM
DTC B1517
B2455
Cellular Phone Microphone Circuit Malfunction
OnStar® VCIM
DTC B2455
B2470
Cellular Phone Antenna Circuit Malfunction
OnStar® VCIM
DTC B2470
B2476
Cellular Phone Select Service Switch Malfunction
OnStar® VCIM
DTC B2476
B2482
Cellular Phone Select Switch Range/Performance
OnStar® VCIM
DTC B2482
B2483
GPS Sensor Circuit Low
OnStar® VCIM
DTC B2483 or B2484
B2484
GPS Sensor Circuit Open
OnStar® VCIM
DTC B2483 or B2484
B2530
Front Fog Lamps Control Circuit
BCM
DTC B2530
B2580
Headlamp High Beam Control Circuit
BCM
DTC B2580
B2625
Display Dimming Pulse Width Modulation (PWM) Output Circuit
BCM
DTC B2625
B2645
Ambient Light Sensor Circuit
BCM
DTC B2645
B2705
Gearshift Unlock Circuit
BCM
DTC B2705
B2750
Horn Relay Coil Circuit
BCM
DTC B2750
B2961
Key In Ignition Circuit
BCM
DTC B2961
B3031
Security System Controller In Learn Mode
TDM
DTC B3031
B3055
No Transponder Modulation or No Transponder
TDM
DTC B3055
B3060
Unprogrammed Transponder Identification Code Received
TDM
DTC B3060
B3105
Keyless Entry System Key Fobs Not Programmed
RCDLR
DTC B3105
B3109
Keyless Entry Transmitter 1 Low Battery
RCDLR
DTC B3109, B3110, B3111, or B3112
B3110
Keyless Entry Transmitter 2 Low Battery
RCDLR
B3111
Keyless Entry Transmitter 3 Low Battery
RCDLR
B3112
Keyless Entry Transmitter 4 Low Battery
RCDLR
B3265
Trunk Release Output Circuit
BCM
DTC B3265
B3715
Front Wiper Relay Drive Circuit
BCM
DTC B3715, B3716, B3717, B3718, or B3719
B3716
Front Wiper Relay Drive Circuit Range/Performance
BCM
B3717
Front Wiper Relay Drive Circuit Low
BCM
B3718
Front Wiper Relay Drive Circuit High
BCM
B3719
Front Wiper Relay Drive Circuit Open
BCM
B3794
Cruise Control Function Request Circuit
BCM
DTC B3794
B3903
Stop Lamp Relay Circuit
BCM
DTC B3903
B3935
Transponder Authentication Error
TDM
DTC B3935
B3948
Left Front Turn Signal Circuit
BCM
DTC B3948
B3949
Right Front Turn Signal Circuit
BCM
DTC B3949
B3950
Left Rear Turn Signal Circuit
BCM
DTC B3950
B3951
Right Rear Turn Signal Circuit
BCM
DTC B3951
B3976
Unconfigured Transponder/Vehicle Configuration Not Programmed
TDM
DTC B3976
C0000
Vehicle Speed Information Circuit
PSCM
DTC C0000
C0035
LF Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0040
RF Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0045
LR Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0050
RR Wheel Speed Sensor Circuit
EBCM
DTC C0035-C0050
C0110
Pump Motor Circuit
EBCM
DTC C0110
C0161
ABS/TCS Brake Switch Circuit
EBCM
DTC C0161
C0176
System Thermal Error
PSCM
DTC C0176
C0267
Low Brake Fluid Indicated
EBCM
DTC C0267
C0475
Electric Steering Motor Circuit
PSCM
DTC C0475
C0545
Steering Wheel Torque Input Sensor
PSCM
DTC C0545
C0550
EBCM
DTC C0550
C0551
EBCM
DTC C0551
C0561
System Disabled Information Stored
EBCM
DTC C0561 or P0856
C0845
PSCM
DTC C0845
C0895
Device Voltage
PSCM
DTC C0895
C0899
Device Voltage Low
EBCM
DTC C0899
C0900
Device Voltage High
EBCM
DTC C0900
P0010
Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit
ECM
DTC P0010, P0011, P0013, or P0014
P0011
Intake Camshaft Position (CMP) System Performance
ECM
P0013
Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit
ECM
P0014
Exhaust Camshaft Position (CMP) System Performance
ECM
P0016
Crankshaft Position (CKP) - Intake Camshaft Position (CMP) Correlation
ECM
DTC P0016 for the 2.2L (L61) engine
or
DTC P0016 for the 2.4L engine
P0017
Crankshaft Position (CKP) - Exhaust Camshaft Position (CMP) Correlation
ECM, PCM
DTC P0017 for the 2.0L engine
or
DTC P0017 for the 2.4L engine
P0030
HO2S Heater Control Circuit Sensor 1
ECM, PCM
• DTC P0030 or P0036 for the 2.0L engine
• DTC P0030, P0036, P0053, P0054, P0135, or P0141 for the 2.2L (L61) engine
• DTC P0030, P0036, P0053, P0054, P0135, or P0141 for the 2.4L engine
P0033
Supercharger Bypass Valve Solenoid Control Circuit
PCM
DTC P0033
P0036
HO2S Heater Control Circuit Sensor 2
ECM, PCM
P0053
HO2S Heater Resistance Sensor 1
ECM
or
P0054
HO2S Heater Resistance Sensor 2
ECM
or
P0068
Throttle Body Airflow Performance
ECM, PCM
• DTC P0068 for the 2.0L engine
• DTC P0068 or P0121 for the 2.2L (L61) engine
• DTC P0068 or P0121 for the 2.4L engine
P0069
Manifold Absolute Pressure - Barometric Pressure Correlation
PCM
DTC P0069
P0096
Intake Air Temperature (IAT) Sensor 2 Performance
PCM
DTC P0096
P0097
Intake Air Temp Low Voltage
PCM
DTC P0097
P0098
Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage
PCM
DTC P0098
P0101
Mass Air Flow (MAF) Sensor Performance
ECM, PCM
• DTC P0101 for the 2.0L engine
• DTC P0101 or P1101 for the 2.2L (L61) engine
• DTC P0101 or P1101 for the 2.4L engine
P0102
Mass Air Flow (MAF) Sensor Circuit Low Frequency
ECM, PCM
• DTC P0102 for the 2.0L engine
• DTC P0102 or P0103 for the 2.2L (L61) engine
• DTC P0102 or P0103 for the 2.4L engine
P0103
Mass Air Flow (MAF) Sensor Circuit High Frequency
ECM, PCM
• DTC P0103 for the 2.0L engine
P0106
Manifold Absolute Pressure (MAP) Sensor Performance
ECM, PCM
• DTC P0106 for the 2.0L engine
• DTC P0106
• DTC P0106 for the 2.4L engine
P0107
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
ECM, PCM
• DTC P0107 for the 2.0L engine
• DTC P0107 or P0108 for the 2.2L (L61) engine
• DTC P0107 or P0108 for the 2.4L engine
P0108
Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
ECM, PCM
• DTC P0108 for the 2.0L engine
P0111
Intake Air Temperature (IAT) Sensor 1 Performance
PCM
DTC P0111
P0112
Intake Air Temperature (IAT) Sensor 1 Circuit Low Voltage
ECM, PCM
• DTC P0112 for the 2.0L engine
• DTC P0112 or P0113 for the 2.2L (L61) engine
• DTC P0112 or P0113 for the 2.4L engine
P0113
Intake Air Temperature (IAT) Sensor 1 Circuit High Voltage
ECM, PCM
• DTC P0113 for the 2.0L engine
P0116
Engine Coolant Temperature (ECT) Sensor Performance.
ECM, PCM
• DTC P0116 for the 2.0L engine
• DTC P0116 for the 2.2L (L61) engine
• DTC P0116 for the 2.4L engine
P0117
Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
ECM, PCM
• DTC P0117 for the 2.0L engine
• DTC P0117 or P0118 for the 2.2L (L61) engine
• DTC P0117 or P0118 for the 2.4L engine
P0118
Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
ECM, PCM
• DTC P0118 for the 2.0L engine
P0120
Throttle Position (TP) Sensor 1 Circuit
ECM, PCM
• DTC P0120 for the 2.0L engine
• DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 for the 2.2L (L61) engine
• DTC P0120, P0122, P0123, P0220, P0222, P0223, or P2135 for the 2.4L engine
P0121
Throttle Position (TP) Sensor 1 Performance
ECM, PCM
• DTC P0121 for the 2.0L engine
P0122
Throttle Position (TP) Sensor 1 Circuit Low Voltage
ECM, PCM
• DTC P0122 for the 2.0L engine
P0123
Throttle Position (TP) Sensor 1 Circuit High Voltage
ECM, PCM
• DTC P0123 for the 2.0L engine
P0125
Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
PCM
DTC P0125 for the 2.0L engine
P0128
Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
ECM, PCM
• DTC P0128 for the 2.0L engine
• DTC P0128 for the 2.2L (L61) engine
• DTC P0128 for the 2.4L engine
P0130
HO2S Circuit Sensor 1
PCM
DTC P0130 for the 2.0L engine
P0131
HO2S Circuit Low Voltage Sensor 1
ECM, PCM
• DTC P0131 for the 2.0L engine
• DTC P0131, P0132, P0137, or P0138 for the 2.2L (L61) engine
• DTC P0131, P0132, P0137, or P0138 for the 2.4L engine
P0132
HO2S Circuit High Voltage Sensor 1
ECM, PCM
• DTC P0132 for the 2.0L engine
P0133
HO2S Slow Response Sensor 1
ECM, PCM
• DTC P0133 for the 2.0L engine
• DTC P0133, P0134, P0140, P1133, P2A00, or P2A01 for the 2.2L (L61) engine
• DTC P0133, P0134, P0140, P1133, P2A00, or P2A01 for the 2.4L engine
P0134
HO2S Circuit Insufficient Activity Sensor 1
ECM, PCM
• DTC P0134 for the 2.0L engine
P0135
HO2S Heater Performance Sensor 1
ECM, PCM
• DTC P0135 for the 2.0L engine
P0136
HO2S Circuit Sensor 2
PCM
DTC P0136
P0137
HO2S Circuit Low Voltage Sensor 2
ECM, PCM
• DTC P0137 for the 2.0L engine
P0138
HO2S Circuit High Voltage Sensor 2
ECM, PCM
• DTC P0138 for the 2.0L engine
P0140
HO2S Circuit Insufficient Activity Sensor 2
ECM, PCM
• DTC P0140 for the 2.0L engine
P0141
HO2S Heater Performance Sensor 2
ECM, PCM
• DTC P0141 for the 2.0L engine
P0171
Fuel Trim System Lean
ECM, PCM
• DTC P0171 for the 2.0L engine
• DTC P0171 or P0172 for the 2.2L (L61) engine
• DTC P0171 or P0172 for the 2.4L engine
P0172
Fuel Trim System Rich
ECM, PCM
• DTC P0172 for the 2.0L engine
P0201
Injector 1 Control Circuit
ECM, PCM
• DTC P0201, P0202, P0203, or P0204 for the 2.0L engine
• DTC P0201, P0202, P0203, or P0204 for the 2.2L (L61) engine
• DTC P0201, P0202, P0203, or P0204 for the 2.4L engine
P0202
Injector 2 Control Circuit
ECM, PCM
P0203
Injector 3 Control Circuit
ECM, PCM
P0204
Injector 4 Control Circuit
ECM, PCM
P0218
Transmission Fluid Overtemperature
TCM
DTC P0218
P0220
Throttle Position (TP) Sensor 2 Circuit
ECM, PCM
• DTC P0220 for the 2.0L engine
P0222
Throttle Position (TP) Sensor 2 Circuit Low Voltage
ECM, PCM
• DTC P0222 for the 2.0L engine
P0223
Throttle Position (TP) Sensor 2 Circuit High Voltage
ECM, PCM
• DTC P0223 for the 2.0L engine
P0230
Fuel Pump Relay Control Circuit
ECM, PCM
• DTC P0230 for the 2.0L engine
• DTC P0230 for the 2.2L engine
• DTC P0230 for the 2.4L engine
P023A
Charge Air Cooler (CAC) Coolant Pump Relay Control Circuit
PCM
DTC P023A
P0300
Engine Misfire Detected
ECM, PCM
• DTC P0300 for the 2.0L engine
• DTC P0300 for the 2.2L (L61) engine
• DTC P0300 for the 2.4L engine
P0315
Crankshaft Position (CKP) System Variation Not Learned
ECM, PCM
• DTC P0315 for the 2.0L engine
• DTC P0315 for the 2.2L (L61) engine
• DTC P0315 for the 2.4L engine
P0324
Knock Sensor (KS) Module Performance
ECM
DTC P0324, P0325, P0326, P0327, or P0328
P0325
Knock Sensor (KS) Circuit
ECM, PCM
• DTC P0325 for the 2.0L engine
• DTC P0325, P0326, P0327, or P0328 for the 2.2L (L61) engine
• DTC P0324, P0325, P0326, P0327, or P0328
P0326
Knock Sensor (KS) Performance
ECM, PCM
• DTC P0326 for the 2.0L engine
• DTC P0324, P0325, P0326, P0327, or P0328 for the 2.4L engine
P0327
Knock Sensor (KS) Circuit Low Voltage
ECM, PCM
• DTC P0327 for the 2.0L engine
P0328
Knock Sensor (KS) Circuit High Voltage
ECM
or
P0335
Crankshaft Position (CKP) Sensor Circuit
ECM, PCM
• DTC P0335 for the 2.0L engine
• DTC P0335 or P0336 for the 2.2L (L61) engine
• DTC P0335 or P0336 for the 2.4L engine
P0336
Crankshaft Position (CKP) Sensor Performance
ECM, PCM
• DTC P0336 for the 2.0L engine
P0340
Intake Camshaft Position (CMP) Sensor Circuit
ECM, PCM
• DTC P0340 for the 2.0L engine
• DTC P0340 or P0341 for the 2.2L (L61) engine
• DTC P0340, P0341, P0365, or P0366 for the 2.4L engine
P0341
Camshaft Position (CMP) Sensor Performance
ECM, PCM
• DTC P0341 for the 2.0L engine
P0351
Ignition Coil 1 Control Circuit
ECM, PCM
• DTC P0351-P0354 for the 2.0L engine
• DTC P0351-P0354 for the 2.2L (L61) engine
• DTC P0351-P0354 for the 2.4L engine
P0352
Ignition Coil 2 Control Circuit
ECM, PCM
P0353
Ignition Coil 3 Control Circuit
ECM, PCM
P0354
Ignition Coil 4 Control Circuit
ECM, PCM
P0365
Exhaust Camshaft Position (CMP) Sensor Circuit
ECM
P0366
Exhaust Camshaft Position (CMP) Sensor Performance
ECM
P0411
Secondary Air Injection (AIR) System Incorrect Air Flow Detected
ECM
DTC P0411
P0412
Secondary Air Injection (AIR) Solenoid Control Circuit
ECM
DTC P0412 or P0418
P0418
Secondary Air Injection (AIR) Pump Control Circuit
ECM
DTC P0412 or P0418
P0420
Catalyst System Low Efficiency
ECM, PCM
• DTC P0420 for the 2.0L engine
• DTC P0420 for the 2.2L (L61) engine
• DTC P0420 for the 2.4L engine
P0442
Evaporative Emission (EVAP) System Small Leak Detected
ECM, PCM
• DTC P0442 for the 2.0L engine
• DTC P0442 for the 2.2L (L61) engine
• DTC P0442 for the 2.4L engine
P0443
Evaporative Emission (EVAP) Purge Solenoid Control Circuit
ECM, PCM
• DTC P0443 for the 2.0L engine
• DTC P0443 or P0449 for the 2.2L (L61) engine
• DTC P0443 or P0449 for the 2.4L engine
P0446
Evaporative Emission (EVAP) Vent System Performance
ECM, PCM
• DTC P0446 for the 2.0L engine
• DTC P0446 for the 2.2L (L61) engine
• DTC P0446 for the 2.4L engine
P0449
Evaporative Emission (EVAP) Vent Solenoid Control Circuit
ECM, PCM
• DTC P0449 for the 2.0L engine
P0451
Fuel Tank Pressure (FTP) Sensor Performance
ECM, PCM
• DTC P0451 for the 2.0L engine
• DTC P0451, P0452, P0453, or P0454 for the 2.2L (L61) engine
• DTC P0451, P0452, P0453, or P0454 for the 2.4L engine
P0452
Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage
ECM, PCM
• DTC P0452 for the 2.0L engine
P0453
Fuel Tank Pressure (FTP) Sensor Circuit High Voltage
ECM, PCM
• DTC P0453 for the 2.0L engine
P0454
Fuel Tank Pressure (FTP) Sensor Intermittent
ECM, PCM
• DTC P0454 for the 2.0L engine
P0455
Evaporative Emission (EVAP) System Large Leak Detected
ECM, PCM
• DTC P0455 for the 2.0L engine
• DTC P0455 for the 2.2L (L61) engine
• DTC P0455 for the 2.4L engine
P0461
Fuel Level Sensor Performance
ECM, PCM
DTC P0461
P0462
Fuel Level Sensor Circuit Low Voltage
ECM, PCM
DTC P0462
P0463
Fuel Level Sensor Circuit High Voltage
ECM, PCM
DTC P0463
P0464
Fuel Level Sensor Circuit Intermittent
ECM, PCM
DTC P0464
P0480
Cooling Fan Relay 1 Control Circuit
ECM, PCM
DTC P0480 or P0481
P0481
Cooling Fan Relay 2 Control Circuit
ECM, PCM
DTC P0480 or P0481
P0496
Evaporative Emission (EVAP) System Flow During Non-Purge
ECM, PCM
• DTC P0496 for the 2.0L engine
• DTC P0496 for the 2.2L (L61) engine
• DTC P0496 for the 2.4L engine
P0502
Vehicle Speed Sensor (VSS) Circuit Low Voltage
ECM, PCM
DTC P0502 for the Getrag 5 Speed transmission
or
DTC P0502 for the MU3 transaxle
P0503
Vehicle Speed Sensor (VSS) Circuit Intermittent
ECM, PCM
DTC P0503 for the Getrag 5 Speed transmission
or
DTC P0503 for the MU3 transaxle
P0506
Idle Speed Low
ECM, PCM
• DTC P0506 for the 2.0L engine
• DTC P0506 or P0507 for the 2.2L (L61) engine
• DTC P0506 or P0507 for the 2.4L engine
P0507
Idle Speed High
ECM, PCM
• DTC P0507 for the 2.0L engine
P0520
Engine Oil Pressure (EOP) Sensor Circuit
ECM, PCM
DTC P0520
P0532
(A/C) Air Conditioning Pressure Sensor Circuit Low Voltage
ECM, PCM
DTC P0532 or P0533
P0533
(A/C) Air Conditioning Pressure Sensor Circuit High Voltage
ECM, PCM
DTC P0532 or P0533
P0562
System Voltage Low
ECM, PCM
DTC P0562
TCM
DTC P0562
P0563
System Voltage High
ECM, PCM
DTC P0563
TCM
DTC P0563
P0575
Cruise Control Switch Signal Circuit
ECM, PCM
DTC P0575
P0601
Control Module Read Only Memory (ROM)
ECM, PCM
• DTC P0601, P0602, P0603, P0604, P0605, P0606, P0607, P060E, P1600, P1621, P1627, P1681, P1683, or P2610 for the 2.0L engine
• DTC P0601, P0602, P0603, P0604, P0606, P0607, P060D, P062F, or P2610 for the 2.2L (L61) engine
• DTC P0601, P0602, P0603, P0604, P0606, P0607, P060D, P062F, or P2610 for the 2.4L engine
Transmission Control Module (TCM) Read Only Memory (ROM)
TCM
DTC P0601, P0602, P0603, or P0604
P0602
Control Module Not Programmed
ECM, PCM
Transmission Control Module (TCM) Not Programmed
TCM
P0603
Control Module Long Term Memory Reset
ECM, PCM
Transmission Control Module (TCM) Long Term Memory Reset
TCM
P0604
Control Module Random Access Memory (RAM)
ECM, PCM
Transmission Control Module (TCM) Random Access Memory (RAM)
TCM
P0606
Control Module Internal Performance
ECM, PCM
P0607
Control Module Performance
ECM, PCM
P060D
Control Module Accelerator Pedal Position (APP) System Performance
ECM
or
P0615
Starter Relay Control Circuit
ECM, PCM
DTC P0615
P0621
Generator L-Terminal Circuit
ECM, PCM
DTC P0621
P0622
Generator F-Terminal Circuit
ECM, PCM
DTC P0622
P062F
Control Module Long Term Memory Performance
ECM
or
Transmission Control Module (TCM) Long Term Memory Performance
TCM
DTC P062F
P0641
5-Volt Reference 1 Circuit
ECM, PCM
• DTC P0641 for the 2.0L engine
• DTC P0641 or P0651 for the 2.2L (L61) engine
• DTC P0641 or P0651 for the 2.4L engine
P0645
Air Conditioning (A/C) Clutch Relay Control Circuit
ECM, PCM
DTC P0645
P0650
Malfunction Indicator Lamp (MIL) Control Circuit
ECM, PCM
• DTC P0650 for the 2.0L engine
• DTC P0650 for the 2.2L (L61) engine
• DTC P0650 for the 2.4L engine
P0651
5-Volt Reference 2 Circuit
ECM, PCM
• DTC P0651 for the 2.0L engine
P0685
Engine Controls Ignition Relay Control Circuit
ECM
DTC P0685, P0689, or P0690 for the 2.2L (L61) engine
or
DTC P0685, P0689, or P0690 for the 2.4L engine
P0689
Engine Controls Ignition Relay Feedback Circuit Low Voltage
ECM
or
P0690
Engine Controls Ignition Relay Feedback Circuit High Voltage
ECM
or
P0700
Transmission Control Module (TCM) Requested MIL Illumination
ECM
DTC P0700 for the 2.2L (L61) engine
or
DTC P0700 or P1700 for the 2.4L engine
P0705
Transmission Range (TR) Switch Circuit
TCM
DTC P0705
P0711
Transmission Fluid Temperature (TFT) Sensor Performance
TCM
DTC P0711
P0712
Transmission Fluid Temperature (TFT) Sensor Circuit Low Voltage
TCM
DTC P0712
P0713
Transmission Fluid Temperature (TFT) Sensor Circuit High Voltage
TCM
DTC P0713
P0716
Input Speed Sensor Performance
TCM
DTC P0716
P0717
Input Speed Sensor Circuit Low Voltage
TCM
DTC P0717
P0719
Brake Switch Circuit Low Voltage
ECM, PCM
DTC P0719
TCM
DTC P0719
P0722
Output Speed Sensor Circuit Low Voltage
TCM
DTC P0722
P0723
Output Speed Sensor Circuit Intermittent
TCM
DTC P0723
P0724
Brake Switch Circuit High Voltage
ECM, PCM
DTC P0724
TCM
DTC P0724
P0741
Torque Converter Clutch (TCC) System - Stuck Off
TCM
DTC P0741
P0742
Torque Converter Clutch (TCC) System - Stuck On
TCM
DTC P0742
P0751
1-2 Shift Solenoid (SS) Valve Performance - No First or Fourth Gear
TCM
DTC P0751
P0752
1-2 Shift Solenoid (SS) Valve Performance - No Second or Third Gear
TCM
DTC P0752
P0756
2-3 Shift Solenoid (SS) Valve Performance - No First or Second Gear
TCM
DTC P0756
P0757
2-3 Shift Solenoid (SS) Valve Performance - No Third or Fourth Gear
TCM
DTC P0757
P0833
Clutch Pedal Switch 2 Circuit
ECM, PCM
DTC P0833 for the Getrag 5 Speed Transmission
or
DTC P0833 for the MU3 transaxle
P0842
Transmission Fluid Pressure (TFP) Sensor Circuit Low Voltage
TCM
DTC P0842
P0843
Transmission Fluid Pressure (TFP) Sensor Circuit High Voltage
TCM
DTC P0843
P0856
Traction Control Torque Request Circuit
ECM
DTC C0561 or P0856
P0961
Line Pressure Control (PC) Solenoid System Performance
TCM
DTC P0961
P0973
1-2 Shift Solenoid (SS) Control Circuit Low Voltage
TCM
DTC P0973
P0974
1-2 Shift Solenoid (SS) Control Circuit High Voltage
TCM
DTC P0974
P0976
2-3 Shift Solenoid (SS) Control Circuit Low Voltage
TCM
DTC P0976
P0977
2-3 Shift Solenoid (SS) Control Circuit High Voltage
TCM
DTC P0977
P1101
Intake Air Flow System Performance
ECM, PCM
• DTC P1101 for the 2.0L engine
P1133
HO2S Insufficient Switching Sensor 1
ECM, PCM
• DTC P1133 for the 2.0L engine
P1174
Fuel Trim Cylinder Balance
ECM
DTC P1174 for the 2.2L (L61) engine
or
DTC P1174 for the 2.4L engine
P1182
Supercharger Inlet Pressure Sensor Performance
PCM
DTC P1182
P1183
Supercharger Inlet Pressure Sensor Circuit Low Voltage
PCM
DTC P1183
P1184
Supercharger Inlet Pressure Sensor Circuit High Voltage
PCM
DTC P1184
P1258
Engine Coolant Over Temperature - Fuel Disabled
ECM, PCM
DTC P1258
P1400
Cold Start Emission Reduction Control System
ECM
DTC P1400 for the 2.2L (L61) engine
or
DTC P1400 for the 2.4L engine
P1516
Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
ECM, PCM
• DTC P1516 for the 2.0L engine
• DTC P1516, P2101, P2119, or P2176 for the 2.2L (L61) engine
• DTC P1516, P2101, P2119, or P2176 for the 2.4L engine
P1574
Stop Lamp Switch Circuit
ECM, PCM
DTC P1574
P1629
Theft Deterrent Fuel Enable Signal Not Received
ECM, PCM
DTC P1629
P1630
Theft Deterrent Learn Mode Active
ECM, PCM
DTC P1630
P1631
Theft Deterrent Fuel Enable Signal Not Correct
ECM, PCM
DTC P1631
P1632
Theft Deterrent Fuel Disable Signal Received
ECM, PCM
DTC P1632
P1668
Generator L-Terminal Control Circuit
ECM, PCM
DTC P1668
P1680
PCM
DTC P1680
P1681
Control Module Throttle Position (TP) System Performance
PCM
P1682
Ignition 1 Switch Circuit 2
ECM, PCM
• DTC P1682 for the 2.0L engine
• DTC P1682 for the 2.2L (L61) engine
• DTC P1682 for the 2.4L engine
P1810
Transmission Fluid Pressure (TFP) Position Switch Circuit
TCM
DTC P1810
P1811
Maximum Adapt and Long Shift
TCM
DTC P1811
P1816
Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Park/Neutral (P/N) with Drive Ratio
TCM
DTC P1816
P1818
Transmission Fluid Pressure (TFP) Valve Position Switch Indicates Drive without Drive Ratio
TCM
DTC P1818
P2101
Control Module Throttle Actuator Position Performance
ECM, PCM
• DTC P2101 for the 2.0L engine
P2119
Throttle Closed Position Performance
ECM, PCM
• DTC P2119 for the 2.0L engine
P2120
Accelerator Pedal Position (APP) Sensor 1 Circuit
ECM, PCM
• DTC P2120 for the 2.0L engine
• DTC P2120, P2122, P2123, P2125, P2127, P2128, or P2138 for the 2.2L (L61) engine
• DTC P2120, P2122, P2123, P2125, P2127, P2128, or P2138 for the 2.4L engine
P2122
Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
ECM, PCM
• DTC P2122 for the 2.0L engine
P2123
Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
ECM, PCM
• DTC P2123 for the 2.0L engine
P2125
Accelerator Pedal Position (APP) Sensor 2 Circuit
ECM, PCM
• DTC P2125 for the 2.0L engine
P2127
Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
ECM, PCM
• DTC P2127 for the 2.0L engine
P2128
Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
ECM, PCM
• DTC P2128 for the 2.0L engine
P2135
Throttle Position (TP) Sensor 1-2 Correlation
ECM, PCM
• DTC P2135 for the 2.0L engine
P2138
Accelerator Pedal Position (APP) Sensor 1-2 Correlation
ECM, PCM
• DTC P2138 for the 2.0L engine
P2176
Minimum Throttle Position Not Learned
ECM, PCM
• DTC P2176 for the 2.0L engine
P2227
Barometric Pressure (BARO) Sensor Performance
PCM
DTC P2227
P2228
Barometric Pressure (BARO) Sensor Circuit Low Voltage
PCM
DTC P2228
P2229
Barometric Pressure (BARO) Sensor Circuit High Voltage
PCM
DTC P2229
P2430
Secondary Air Injection (AIR) System Pressure Sensor Circuit
ECM
DTC P2430, P2431, P2432, or P2433
P2431
Secondary Air Injection (AIR) System Pressure Sensor Performance
ECM
P2432
Secondary Air Injection (AIR) System Pressure Sensor Circuit Low Voltage
ECM
P2433
Secondary Air Injection (AIR) System Pressure Sensor Circuit High Voltage
ECM
P2440
Secondary Air Injection (AIR) System Shut-Off Valve Stuck Open
ECM
DTC P2440
P2444
Secondary Air Injection (AIR) System Pump Stuck On
ECM
DTC P2444
P2534
Ignition 1 Switch Circuit Low Voltage
TCM
DTC P2534
P2535
Ignition 1 Switch Circuit High Voltage
ECM, PCM
DTC P2535
P2544
Transmission Torque Request Circuit
ECM
DTC P2544 for the 2.2L (L61) engine
or
DTC P2544 for the 2.4L engine
P2610
Control Module Ignition Off Timer Performance
ECM
or
P2763
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit High Voltage
TCM
DTC P2763
P2764
Torque Converter Clutch (TCC) Pressure Control (PC) Solenoid Control Circuit Low Voltage
TCM
DTC P2764
P2A00
HO2S Circuit Closed Loop (CL) Performance Sensor 1
ECM
or
P2A01
ECM
or
U0001
PCM
DTC U0001
U0100
Lost Communication with ECM/PCM
ABS, BCM, TCM
DTC U0100-U0299
U0101
Lost Communication with TCM
ABS, BCM, ECM, PCM
DTC U0100-U0299
U0107
Lost Communication with Throttle Actuator Control Module
ECM, PCM
DTC U0100-U0299
U0121
Lost Communication with Antilock Brake System (ABS) Control Module
BCM, ECM, PCM, TCM
DTC U0100-U0299
U0126
Lost Communication withPower Steering Control Module (PSCM)
BCM, ECM, PCM
DTC U0100-U0299
U0140
Lost Communication with Body Control Module (BCM)
RCDLR, VCIM
DTC U0100-U0299
U1300
Class 2 Data Link Low
PCM
DTC U1300, U1301, or U1305
U1301
Class 2 Data Link High
PCM
U1305
Class 2 Data Link Low or High
PCM
U2100
Controller Area Network (CAN) Bus Communication
BCM, EBCM, ECM, IPC, PCM, PSCM, Radio, SDM, TCM, VCIM
DTC U2100
U2103
Fewer Controllers On Bus Than Programmed
DTC U2103
U2105
Lost Communications with Engine Control System
BCM, EBCM, PSCM, TCM
DTC U2105-U2199
U2106
Lost Communications with Transmission Control System
BCM, EBCM, ECM
DTC U2105-U2199
U2107
Lost Communications with Body Control System
DTC U2105-U2199
U2108
Lost Communications with ABS/TCS Control System
BCM
DTC U2105-U2199
U2109
Lost Communications with Powertrain Multiple Control System
EBCM
DTC U2105-U2199
U2111
Lost Communications with Steering Control System
BCM
DTC U2105-U2199
U2113
Lost Communications with Sensing Diagnostic Module (SDM)
BCM
DTC U2105-U2199
U2116
Lost Communications with Instrument Panel Cluster (IPC)
BCM
DTC U2105-U2199
U2125
Lost Communications with Mobile Communications Control Systems
BCM
DTC U2105-U2199
U2137
Lost Communications with Vehicle Theft Deterrent (VTD)
BCM
DTC U2105-U2199
U2172
Lost Communications with Digital Radio Receiver (DRR)
BCM
DTC U2105-U2199
023
Seat Belt Tension Sensor Circuit Out of Range
PPS
DTC 023
024
PPS Ignition 1 Voltage Performance
PPS
DTC 024
063
PPS Out of Calibration
PPS
DTC 063
064
Communication/ID Performance
PPS
DTC 064
065
PPS
DTC 065
© 2009 General Motors Corporation. All rights reserved.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
