2 issues...
Old May 3, 2011 | 09:50 PM
JimHarr18's Avatar
2 issues...
so i have 2 issues with my ss/sc. first one should be easy. i'm looking for a new hid harness that will still give me hi beams in my retro's. they use morimoto mini's. the kit i'm currently using is from the retrofit source, and i find that the bulbs either flicker, or vibrate, or something, i just know it's annoying, and i want to keep the hi beams functional. so i'm just looking for a good harness, something that's also designed for a larger power connector. this one i had to actually cut the power connection ring a bit just to get it to fit, which also may contribute to my possible flickering.
my second issue is a metal squealing sound coming from my left front wheel. anytime i turn left, or have the suspension move i hear the noise, and it's only coming from the left side. very annoying, makes me feel like i'm driving a cheap piece of crap. heh. i know i need an axle boot replaced, and my fiance had a similar noise and had her boot replaced on her old jetta. once the boot was replaced the noise went away, so i'm hoping for that. so, just looking for some opinions if that could be it.
Old May 3, 2011 | 09:51 PM
redcobalt07's Avatar
check the wheel hub
Old May 3, 2011 | 10:24 PM
JimHarr18's Avatar
wheel hub... hmmm... did just have the brakes done.
keepyourmacon
May 12, 2015 07:30 PM
Pumpkinking13
Nov 8, 2014 08:54 PM
MajorCB
May 15, 2014 01:40 AM
3fo893013L
Mar 24, 2006 11:50 AM
Lucky 13
Feb 27, 2006 08:24 PM
