2 problems at once
Old Feb 18, 2008 | 03:39 PM
methodman2424's Avatar
2 problems at once
Well my engine light has been on off on off for quite some time now. Good ol PO1701 code. Not really sure if its an o2 or not but I do have a injen CAI but its been on for awhile with out any probs. Well today my damn airbag light came on with it saying "service airbag" well I know i wasn't hit and did not hit anything so has anybody had these peoblems? Solutions? Dealer said o2 is good under warranty 3yr 36,000 mile and I am over on the mileage. BTW car is a 06 ss/sc cobalt
Old Feb 18, 2008 | 03:41 PM
D4u2s0t's Avatar
p0171 is safe to delete, it's from your intake, and isn't doing anything bad to your car. not sure about the airbag light though.
Old Feb 18, 2008 | 03:44 PM
Well I ran a scanner on the code and it said air fuel ratio but you are telling me its not an o2
Old Feb 18, 2008 | 04:28 PM
yel-low's Avatar
if i remember right the 171 code is a lean code someone correct me if i am wrong just a check i had this happen to me make sure the oil dipstick is all the way in and did you ever get the newest update from gm or do you have a tune because there is a tsb out there about a idle surge and a 171 lean
Old Feb 18, 2008 | 05:30 PM
D4u2s0t's Avatar
it's from the maf, and because of your intake. safe to delete.
Old Feb 18, 2008 | 05:35 PM
firestorm's Avatar
as far as the airbag kick out your mother in law.
Old Feb 18, 2008 | 05:42 PM
chevysssc's Avatar
i had same code its a lean code im sure its alrightim not sure of your mods but if you get stage two the code wont come back.
Old Feb 18, 2008 | 05:51 PM
MikeyMo84's Avatar
i got that code and it was a vaccum line that had a hole chafed in it from rubbing on top of the trans
Old Sep 11, 2008 | 08:50 PM
outtamymind's Avatar
which vacuum line was it. i'm getting this right now and having a hell of a time trying to figure out what is causing it. i've already had the injectors replaced, gonna check my intake tomorrow and all the vacuum lines for holes.
Old Sep 12, 2008 | 12:03 AM
Coblasts's Avatar
Check your injen didnt get a hole wore in it where it goes into the fender.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
