2006 SS/SC loosing coolant is normal?
Old Apr 27, 2012 | 02:37 PM
Shogokuma's Avatar
did leakdown test, checked the oil, compression test all came back normal what are they missing?
sensor had a bad cable, and thermostat was replaced 2 years ago
slow leak, about a quart ever 2 months
Old Apr 27, 2012 | 03:28 PM
Chevrolet Cust Svc's Avatar
Sorry to hear you're losing coolant, Shogokuma. Have you ever gotten this looked into? I know you're probably on the lookout for some DIY advice; if you decide to get it looked at by a dealer, please let me know!
Sarah
GM Customer Service
Old Apr 27, 2012 | 06:29 PM
Shogokuma's Avatar
well its my dealership who did all that work. they mentioned a pressur release valve under the fuel rail.
Old Apr 27, 2012 | 06:30 PM
bluebalt07's Avatar
Tiny hole in a hose, loose clamp, leak around the pump. Gotta be something along those lines.
Old Apr 27, 2012 | 06:51 PM
Shogokuma's Avatar
but technically its not normal to loose a little bit of coolant right? they even put the dye in the coolant but didnt find anything and then told me its normal to loose a little bit throught the valve...? im confused i thought dex cool system where closed systemp and would never loose coolant.
Old Apr 27, 2012 | 07:09 PM
bluebalt07's Avatar
It's not normal. Sorry if my post gave you that impression, but I agree with you that it should never loose coolant. Not sure what this valve is, maybe though if the valve is stuck slightly open it could be loosing coolant through there? See if they'll replace that valve for you
Old Apr 27, 2012 | 07:12 PM
Mr.Tozzi's Avatar
Loosing coolant is not normal at all, I didn't lose a single drop from the time I got the car in 2008 to last year when I flushed the whole thing and replaced the coolant.
Old Apr 27, 2012 | 07:40 PM
Bubman's Avatar
This.
Old Apr 27, 2012 | 07:44 PM
Shogokuma's Avatar
ok i thought so dex cool is a closed loop dosent seem to burn it tho well thats what they told me.. wierd ill have to bring it to a different dealer see what they say
Old Apr 27, 2012 | 08:37 PM
Shogokuma's Avatar
does anyone have the cooling explosion view of all the hoses?
Solaris99
28
Mar 15, 2017 01:22 PM
brandon04
Oct 21, 2015 07:04 AM
dieGone
Oct 1, 2015 06:27 PM
Iceberg
Sep 28, 2015 01:31 PM
