stuck in the middle of no where P1516
Old Apr 27, 2012 | 02:13 PM
robertmichaels's Avatar
I was on the throttle quite a bit on a hilly road and the car shut down with the DIC saying engine disabled.. plugged my scanner in and have P1516 throttle actuator control module position performance...I checked the plug on the TB and it seems like its plugged in all the way....any ideas??? I'm stuck on the side of the road in the middle of no where......
Old Apr 27, 2012 | 02:15 PM
redcobalt07's Avatar
Disconnect the battery and try again.
Old Apr 27, 2012 | 02:31 PM
Found the problem...all my fault, had the S/C holes plugged, one broke off went threw the by pass and wedged in the throttle body....FML...could have been worse, got a friend coming with tools going to pull the S/C off before I start the car
Old Apr 27, 2012 | 06:28 PM
bluebalt07's Avatar
Having whatever you plug the holes with come loose has always been a concern for me and that's why I left mine open. Your lucky it didn't get pulled into the engine and really cause problems
Old Apr 27, 2012 | 10:28 PM
Malaclypse's Avatar
Whatever you guys are plugging the SC holes with will get stopped by the laminovas for the intercooler in the intake.
Old Apr 28, 2012 | 12:25 AM
bluebalt07's Avatar
Don't count on it. There is open space that goes all the way through the intake mani (in other words the hunk of whatever can go right around the outside of the laminovas and into the engine).
Old Apr 28, 2012 | 04:18 AM
ya, I was really worried when I did this, my friend has a m62 swapped 2.4 ion and used metal weld. His has lasted 2 years so far.. Thats why I opted for welding a bigger piece of flat stock in, I made it big enough where it couldnt fit into the valves....
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Sean Cummings
Tuning
Sep 3, 2015 03:43 PM
