2nd gear hiccup
2nd gear hiccup
Its only happened twice now within the last three months. When at WOT in second gear around 5000 rpm i get a large hiccup that feels like a big knock. The car hesitates for a second and then picks up right where it left off. As of now all I have is the gmpp manifold any ideas on what it could be? I was thinkin plugs.
WOT in this case is wide open throttle, as in flooring it. Which, for me at least, I never do until the car is warmed up.
How much boost are you running? Sometimes with mine I would get a HUGE miss and a backfire with flames, it was the spark blowing out and all the unburned fuel (2.6" w/60s there was A LOT) was igniting out the exhaust system. I would suggest new plugs, or if you already have new plugs, then a closer gap. I used HP tuners to solve my problem, but a closer gap is a good alternative.
WOT is wide open throttle for me and operating temp was at least 160. The thing is I dont have any boost mods right now im only pushing 12-13 lbs. so i wouldnt think i should have any issues with blow-out. I'd say i could take it to the dealer but its not reliably repeatable and what are they going to do anyways?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
