ABS light on....
Old Mar 24, 2010 | 03:40 PM
RazaMaJazz's Avatar
ABS light on....
I tried to read up and figure out what the hell is going on, but I dont really even know what im looking for.
I went to go grab a bite to eat and noticed when I pulled out my driveway that the "ABS" light on my dash was on, and I have no idea why. The car ran fine, but I noticed that it was running a little warmer than it normaly does, usualy is about 178-180, but was runnin at 188-190. Dont know if that has anything to do with the light, or just town driving in general.
Here is a pic of the light.
[IMG][/IMG]
Old Mar 24, 2010 | 04:43 PM
Coblasts's Avatar
In most cases a wheel bearing(Hub) has to be replaced because the wheel sensor is buggered.
You could check the wiring for the wheel sensors at the hubs to make sure they are not shorted or the connector ie dirty etc.
Old Mar 24, 2010 | 06:36 PM
RazaMaJazz's Avatar
So would it be alright to drive on for a bit, I would have to go home, about 100 miles, to get it checked out, or should I get it checked in here somewhere?
Old Mar 24, 2010 | 06:38 PM
DEZZIE41's Avatar
u can drive with the light on all it is telling u is that there is somethign wrong and ur abs is not working
Old Mar 24, 2010 | 06:40 PM
SS/SC Crazer's Avatar
you should be ok to drive it but if you want to know what bearing it is you need an OBD2 scanner. than again it might not be a bearing, it might be something else, but a bearing is the most common! a OBDII scanner is also the only way to turn off the light im most cases.
Old Mar 24, 2010 | 06:42 PM
RazaMaJazz's Avatar
Alright, thanks guys. Didn't want it to be driving on it and my wheel fall off or something.
Old Mar 24, 2010 | 07:16 PM
Killa702's Avatar
i have the same problem its cause my right front wheel bearing is messed up.
the light isnt a big deal
the wheel bearing is lol
Old Mar 24, 2010 | 07:20 PM
ls1fbody's Avatar
Haz l33t wheelz.
I've had an ABS light for weeks. The TechII says it's my right rear wheel speed sensor. You'll be fine. My ABS still works, and believe me, i've used it.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
