ABS light/braking issues
So as of recently, my car shutters when I push the brakes on the highway. I never drove highway in the past year before this. My LS has 25k on it, and is out of warranty. My ABS light came on yesterday. I turned the car off and restarted it. The light did not turn on until 3 miles into my trip. Ever since then, the light has turned on intermittently. I had my brakes checked, and Pep Boys couldn't find anything wrong with them. I asked if the rotors were warped, and they said no. They told me to brake hard while on the highway to make them better.
I've read other posts about a wheel sensor, but I have no idea to diagnose the issue.
I would rather avoid the costly dealer fees. I know it's not very safe not having ABS, but I'm ok with it temporarily as long as my brakes don't give out.
If I can get a more direct diagnosis, I will take it to a local shop for some intelligent exploring.
If that does not help you CAN unplug the ABS fuse so it doesnt go off. You will just NOT have ABS!
Do all 4 wheels have the sensor, or just 2 (sorry I'm bad with brakes)
will there be any codes? it's not a CEL, the actual ABS light is on
Pep Boys wanted $92 to scan them, so I have to find an autozone I guess
autozone will check codes for free. the one i go to lets me take it out to my car as long as i leave my license inside. sounds like a bad abs sensor. how are your pads. If they are too warn this can happen.
so as an update, there were no codes present
but the abs light is on
where can I find these abs sensors to take a look? I couldn't find a repair manual at any autopart stores...
