Abs - wtf ??
mine triggered again, same spot.(backing out of drive way) im gonna have someone scan it this weekend to see what the major malfunction is ******** haha
it happened tues and today.
I got an easy thing to try. Find out which one is doing it with scan. Then unplug the wheel sensor, silicon the back of the connector where wires go into plug, let dry and plug it back in and see if u still have this issue. I had a constant issue with my abs kicking off, especially when driving in rain or through water, blew 2 sensors and replaced ones still did it, 2 years ago I did what I just advised u to do and I never had a problem since . Ripping through water pools and everything . No more issues. I'm gonna bet this may be the issue or at least May have caused a sensor to be almost shot.
check this out, i had a loose coilover. endlink hit the wheel when pulling out of a gas station.
before that it trigger the ABS when i backed into the spot at the gas station, i think maybe the right front was just freaking out. I didnt check the connection when i had the wheel off
i have had the coilover come loose over time on my other wheels but it never trigger the ABS.
i keep hearing a sound like solid cabs when full lock in reverse haha but it was coilovers trying to kill me. I always tell myself to check them every now and then
Ill try your fix out once i get it figured out
Getaway_Driver
13
Aug 30, 2015 02:44 PM
