Air flow hood/cover assembly
Old Jun 28, 2018 | 08:48 PM
Yellow09's Avatar
Clearly the title is a best guess. not really sure what to call this, but I'm hoping someone is familiar with the issue. I'm a complete amateur, but I've had success in the past learning from this forum, so I thought I'd give it a try. This is on an 09 SS. One of the air flow hoses snapped off what i'm calling the air flow hood assembly. I can't find a replacement hood online, and If i did I'm not sure I'd know how to replace it. Can anyone tell me what this thing is called and if it's an easy fix? Any info helps at this point. The car runs fine but vibrates when it's idle. The check engine light is on and the I get the check the gas cap error at least once a day. Thought it was a purge solenoid and bought one to replace but saw the broken hose and I'm assuming that's the real issue.
Attached Thumbnails 20180628_201126.jpg   20180628_201135.jpg   20180628_201145.jpg   20180628_201153.jpg   20180628_201157.jpg
Old Jun 29, 2018 | 09:46 AM
Kolt's Avatar
you'll probably need a new intake, need to pull that nipple out of the hose while holding the latch open so you don't have to replace it too. You might be able to find a new nipple that screws in like the one that goes on the k/n sri but there isn't much meat on the factory tube to screw into.
That hose shouldn't cause any codes for the evap system but it might for the maf. its the fresh air inlet for the pcv system.
Old Jun 29, 2018 | 10:10 AM
Yellow09's Avatar
Thank you, that's a huge help. Do you think I could just replace the intake tube as opposed to replacing the entire intake? As much as I love it, I'm not sure how much more money I want to put into an 09.
Old Jun 29, 2018 | 10:16 AM
This should do it.
https://zzperformance.com/ecotec/lnf...ed-intake-tube
Old Jun 29, 2018 | 10:19 AM
Yellow09's Avatar
Thank you. I was hoping It'd just be a tube and a new valve. Didn't want to replace the hose or the entire intake. Hopefully that does it.
Old Jun 29, 2018 | 10:58 AM
That nipple breaking is really common the part that slowbalt linked to you is the best bet. even if you find another stock pipe it will eventually break again so spend your money wisely with a more durable part
Old Jun 29, 2018 | 11:20 AM
Kolt's Avatar
I forgot about that tube upgrade, def your best bet
Old Jun 29, 2018 | 11:32 AM
Yellow09's Avatar
That a DYI job, you think? Or am I safer taking it to a shop?
Old Jun 29, 2018 | 11:36 AM
exninja's Avatar
Someone has done a repair: https://www.cobaltss.net/forums/how-...r-hose-273968/ Unfortunately looks like the pictures are gone, though.
Definitely a diy job shouldn't take more than 15 mins
Old Jun 29, 2018 | 11:39 AM
Kolt's Avatar
Yes, very easy to replace.
metroplex
May 29, 2016 08:08 PM
09BlkCrusader
Oct 2, 2012 12:58 PM
RaymondT
Jun 13, 2012 11:45 AM
greenlantern459
Mar 8, 2010 01:16 AM
Rubberdude88
2.2L LAP Performance Tech
Dec 3, 2009 12:24 PM
