Annoying tire pressure sensor...
you may have a faulty sensor... does it read right then go to some odd pressure then back? mine did that once... i had the dealership replace it under warranty with no issues... but it lit up my cluster too... just a thought
I have the same problem and have for months. It will go weeks if not months without a problem and then it just randomly ***** the bed and says service TPMS. Normally just prior to this the pressures drop steadily until it is completely offline. I suspect the sensor is failing but with winter coming I'm putting up with it until spring. I'm starting to question if it's not the sensor though because lately I've been getting reports to check my tire pressure and then it goes away in the same second and the pressures are reading fine when this happens.
If it's not the sensor I'd consider BCM but I guess getting the sensor swapped out first is a good option. I hate having my tires pulled and reinstalled though since they're in balance...
Later,
Brad
Sl0wbaltSS
Nov 21, 2018 11:11 PM
DANRICKARD
Oct 1, 2015 12:08 AM
