Another annoying problem!
Old Nov 28, 2007 | 05:24 PM
mkulrey13's Avatar
I also have another problem. My drivers side heated seat just stopped working. The switch still lights up if its low or high but there is no heat to the seat. I have touched nothing that is remotly close to the heated seats or anything. Anyone have this problem and had it fixed? Im afriad to bring to dealer, warrenty is over and they will rape me for something easy probably.
Old Nov 28, 2007 | 05:28 PM
killianss's Avatar
had my passenger seat stop heating for me after i got a new leather insert installed, turns out they had to connect it to the computer with the seatbelt plugged in so the computer would relearn it.
ide check the fuse tho too.
Old Nov 28, 2007 | 05:53 PM
mkulrey13's Avatar
My passanger works fine tho, kidna weird they;d be sept. fuses. Ill give it a go tho!
Well its not the fuse. cant be the plugs as i havent done anythhing to the seats nor has it been to teh dealer to be messed with...wtf
Old Nov 28, 2007 | 08:30 PM
killianss's Avatar
yeah its pretty wild- best bet would be to check wires and fuses,
like i said before the tech took my car for a quick 5-10 min test drive to "relearn" something and its worked ever sence, i thought it was a loose wire or fuse too. Good luck
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
