is anyone having problems with the lower control arm?
Old Feb 12, 2009 | 09:32 PM
arman14's Avatar
i dont know what happened to mine
does anyone know where to get a new one but not the dealer they are too expensive and i cant afford it
Old Feb 14, 2009 | 09:24 AM
css9450's Avatar
What happened to yours? Accident? Bent?
You won't find them at stores; order one from the dealer if you have the ability to install it yourself.
Old Feb 14, 2009 | 09:39 AM
originaladrian's Avatar
u had to have done something, i dont buy that u dont kno wht happened to it.
Old Feb 15, 2009 | 03:55 AM
arman14's Avatar
i have no idea
it was already like that when i got the car
they told me it had no warranty
i know i cant find it on the web
so im gonna have to do that
i have no idea
Old Feb 15, 2009 | 03:58 AM
ls1fbody's Avatar
Haz l33t wheelz.
they still should have fixed it, warrenty or not, they can't sell you a car with a f'ed up control arm, thats dangerous, not to mention probably illegal. They have to replace it, or, you did something, and this is just a poor excuse.
Old Feb 16, 2009 | 01:11 AM
arman14's Avatar
no i didnt do nothing wrong
i thought the problem was at the shock absorbers
but i took my car to some shop and they told me it was the lower arm contol
Old Feb 16, 2009 | 08:23 AM
the point were trying to get at is this.
in order to mess up ur control arm u need to do something pretty major. they dont bend, brake, or other wise get messed from normal driving over pot holes and stuff.
the fact that you didnt know about it makes me think that you prob got your car from a shady dealer.
or ur mechanic is trying to screw u, i would also go get it checked my another place to make sure.
Old Feb 24, 2009 | 08:02 PM
frisco's Avatar
thats a lemon,, they cant sell a fucked up car ,, u still have a certain amount of time to return the car. take it back and get a different car.
Old Feb 25, 2009 | 07:15 AM
JTob's Avatar
What was the original concern? A clunk/noise, and what made you think it was a shock absorber?
Old Feb 25, 2009 | 08:51 AM
Coblasts's Avatar
I had the clunking noise and they thought it was the control arm bushing but it turned out to be the sway bar link(the stand offs for the sway bar to control arm connection)
It was clunking over bumps and I thought it was the shocks originally myself .
I would check those before going with the control arm bushings ,It would be alot less work and a cheaper fix as well.
Old Feb 28, 2009 | 10:55 PM
arman14's Avatar
oh thanks
i thought it was the shocks too but i took my car to some shop and the guy told me it was the lower control arm
but i think im taking it to a different shop
Old May 17, 2010 | 07:29 AM
hasone2's Avatar
Maybe your lug nuts are not tight enough. Does it only make noise a certain revolutions of the tire. Probably lug nuts if you took off your own wheels and hand tightened the nuts back on instead of using an impact drill, even if you cranked them over pretty tight. That will cause a thumping. A broken control arm would be pretty obvious once you get in there and look, does it have a hair line crack or something, otherwise it would snap right. I don't really know. Maybe you just need new control arm bushings. They go bad often.
dennis69
Oct 20, 2015 04:49 PM
yellow dragon
Sep 28, 2015 09:49 PM
Coballin13
Sep 25, 2015 08:43 AM
