clutch problem
Old May 16, 2010 | 07:52 PM
scotch89's Avatar
clutch problem
so when im driving my car and do a pull, then shift into the next gear. my clutch feels like there no pressure, like it just falls to the floor. then when i let it out and clutch again its back to normal. does this mean my clutch is going out?
Old May 16, 2010 | 07:59 PM
Mclovin23's Avatar
having the same issue buddy. i i let it cool off its fine at normal driving but after some pulls it turns to pudding. lol. i would assume the clutch is going
Old May 16, 2010 | 11:21 PM
08SSTCRD's Avatar
Could be clutch hydraulic system failing.
Check your fluid. If its dirty, flush it out with brand new DOT4 fluid and drive the car again. Sometimes that will cure the issue.
Old May 17, 2010 | 01:16 AM
scotch89's Avatar
humm ok....where is the fluid at for the clutch?
Old May 17, 2010 | 01:31 AM
exiged's Avatar
its a shared reservoir with your brake fluid located center - driverside under the hood.
Old May 17, 2010 | 01:34 AM
Traviper's Avatar
mine does the same exact thing
i was told it may be air in the line.
i'm getting the gmpp clutch, so what should i do to keep this from happening again? just bleed it right?
Old May 17, 2010 | 10:40 AM
scotch89's Avatar
ya i would think so^^^^ . ok ill check her out.
Old May 17, 2010 | 10:50 AM
SCcobaltSS's Avatar
Air cant get in the system without a leak or you ran the fluid really low. Put more fluid in and bleed the system.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
